Old September 19th, 2014, 19:32   #1
mk5tdi
Default Steering Wheel Vibration
Question - I've noticed some very faint steering wheel vibration around 30mph under moderate braking. Of course the car doesn't do it all the time. It's a 2010 sedan with 38k miles. When i looked at the pads on the brakes they look like they had plenty of life left (38k on the car and no warning lights). Tires have enough tread and are properly inflated. When I slowly pulled the emergency brake at 30mph I didn't seem to notice the problem (or maybe it was one of those times where the car didn't do it). Any ideas? I'm very gentle on my car, haven't hit any potholes (thank you Arizona roads) and am really dumbfounded on this one...
mk5tdi is offline   Reply With Quote
Old September 19th, 2014, 19:45   #2
maybe368
TDI(s): Happily none
Does it go away after 30? If so it may be a tire balance problem, maybe you threw a weight...Mark
1990 Dodge Ram Cummins Turbo Diesel, 1st Gen
1986 Mercedes 300 SDL traded for the below 240D and 2004 Jaguar XJ-8
1981 Mercedes 240D got it back
1968 Chevrolet Impala SS conv 396 325 HP #s matching
2017 Toyota 4Runner Off Road, loaded Thanks VW looking for older TDI
maybe368 is offline   Reply With Quote
Old September 19th, 2014, 19:48   #3
binky973
TDI(s): 2002 jetta
Fuel Economy: 39mpg avg
you won't normally feel off balance at 30. if it's only when braking your discs need to be turned... happens
binky973 is offline   Reply With Quote
Old September 19th, 2014, 20:08   #4
maybe368
You won't normally feel warped rotors at just a certain speed...Mark
Old September 20th, 2014, 11:22   #5
binky973
TDI(s): 2002 jetta
read his original post, he says he feels it under moderate braking
also, if the discs are warped enough they will "hit" off of the pads and can cause a vibration at any speed depending on the warpage.
Old September 20th, 2014, 12:36   #6
maybe368
You read the post, he said at 30 mph. I am not going to argue with you. I know it is rare to happen at such slow speeds, but imbalance is a possibility, as is warpage. If the problem comes and goes at 30 mph, balance is the likely problem, that is why I asked if it goes away.You have a nice day...Mark
Old September 20th, 2014, 14:53   #7
binky973
TDI(s): 2002 jetta
i read it, but if it were an imbalance it would be present all the time at the speed that it presents, it wouldn't go away, a slightly warped disc can change as it heats and cools so the vibration can come and go and also present at different speeds. i'm not arguing with you, i'm trying to inform you, i have been a mechanic for 18 years, alignment and front end specialist... i KNOW what i'm talking about, an imbalance would ALWAYS be present, not go away and not while braking
Old September 20th, 2014, 15:11   #8
JB05
Fuel Economy: 43/41/40
Try rotating you tires.
JB05 is offline   Reply With Quote
Old September 20th, 2014, 17:11   #9
maybe368
Well Binky, we will have to disagree on that one. Tire imbalance is a vibration almost always between certain speeds, usually highway speeds. There are many other things that could cause it. Don't blow a pop off valve man, life is too short. Whenever somebody says always or never, it raises suspicion of accuracy. I don't mind being informed, but I usually (notice that I didn't say always) want accurate information. I have you beat on the mechanic thing too. I have been wrenching for around 42 years or so. Have a beer and have a good weekend...Mark
Old September 20th, 2014, 18:53   #10
maybe368
No worries man. That is why I asked him if it goes away at higher speeds. He hasn't chimed back in, so we don't know until he does...Mark Did you delete your post?
Steering wheel vibration MikeyT Audi SUVs (Q7 & Q5) 9 August 22nd, 2014 07:16
Steering Wheel Vibration tomsawyer VW B5 Passat TDIs 3 March 2nd, 2007 18:44
Steering wheel vibration Gingerninja VW MKIII-A3/B4 TDIs 2 March 31st, 2004 00:41
steering wheel vibration Nalgene Upgrades (non TDI Engine related) 7 March 11th, 2002 15:02
Steering Wheel Vibration ap22park VW MKIV-A4 TDIs (VE and PD) 3 October 20th, 2000 05:22
Page generated in 0.17847 seconds with 11 queries
[Output: 98.64 Kb. compressed to 84.03 Kb. by saving 14.61 Kb. (14.81%)]
