License Plate Mudflaps/Splash guards
Copying it from vortex, it's a lot to retype
::::::: Mod Name: License Plate Mudflaps/Splash guards
::::::: Why Worth It: Costs nothing but time, helps keep stones from hitting metal, chipping paint, dent and rust prevention.
::::::: Cost: $0, the king of cheap.
::::::: Where to buy: Wherever spare plates are available.
::::::: Time required: ~10 minutes.
::::::: Difficulty: 1 out of 10.
::::::: Tools needed: Tape measure or ruler, a drill, drill bit, TORX tool, marker, tin snips, hammer(optional).
Firstly, I have no idea if this is legal or if it's something you or me could get in trouble for in your state/country. I have not consulted any authorities on this. I am not taking any responsibility in any way for damage to your car, your driving record, or any other issues you may have with this. I am not the smartest person, this may actually be a big no-no. To date, I have had 0 issues, but I am anticipating a stop in the near future.
Now then, with that out of the way. The instructions are simple. Measure the distance between the bolts in the front wheel wells if you want precise measurements, or just go by what I've got in the photos and make the hole a touch larger so you can shimmy the plate around to make sure it doesn't touch metal and cause issues. You only have to drill one hole if you use the one already punched out. You can adjust where the hole is if you want yours to sit higher or lower than mine. Trim the small pieces of metal off the corners so nothing touches metal. Unscrew the two screws from the fenders, don't worry, the liner doesn't shift that much. Hold up the plate and reattach the screws back. You may need to turn your wheel to get a bit of clearance for the TORX tool to get in there. In the future I may end up spraying both sides with some black spray paint or some truck bed liner I have sitting around if it turns out to be highly illegal and nets me tickets. Here are some photos and measurements.
The marks on the right side are from a hammer(optional). I did this in order to get the bottoms to point backwards a little bit.
You can see how I trimmed off some metal on the two corners of the plates so it doesn't touch metal.
Final product, front view. In this shot you can see how the plate is sitting over the plastic and doesn't rub metal on metal.
Finished product, rear view.
I posted that originally 06-29-2013, no tickets so far. No issues. I've gotten thumbs up, surprised and confused stares. Lots of people tell me that there's a plate stuck in my wheel well. One of the plates broke off in the middle, because it was bent while going backwards through ice/snow over winter. The other is ripped in the middle, but it cost me $0. I will be making replacements soon. I have spare plates. So far, zero law enforcement issues, stops or questions. I must say, they do work rather well. I hear rocks hitting those things instead of my car and it makes me smile.
