I'm looking to put HIDs in my 2005 Passat in some way, I'm not sure how putting HIDs in the stock housing will look. Are there any housings that will bolt right in? I'm not entirely sure what I'm looking for, open to any and all suggestions.
You can buy the bulbs that fit your housing, you will have to cut a couple of wires out of the harness and run them to the ballast. You'll need the kit for an H7 bulb. If your present setup is working well I would leave it alone, changing to HID's is hit or miss, you may not be happy with the results. The ones I put in were a big let down.
I did HID conversion on both high and low beam. If I had it to do over I would leave the high beams halogen. HID warm up is a little slow- at least on mine. Otherwise reasonably happy with improvement over stock. Conversion will get you about half way to where you would like it to be. Pretty good bang for the buck however.
