So my parents are having some problems with their 06 TDI Jetta...
It started with the driver side door lock/unlock switch not unlocking the doors, which seems like its probably an issue with the driver door wiring harness which was a common issue on these years. But now the driver side rear door wont lock and the window wont go up or down.
What im trying to see is if a faulty driver side door wiring harness could cause problems with the rear door as well? Or is the rear door most likely a separate issue like a faulty door lock module which was also a common problem?
If someone could save me some time before I go and take apart 2 doors and lock modules that would be great.
