A Al Fischer Active member Joined Aug 5, 2014 Location Clovis, California TDI 2014 Passat SEL Premium Jan 10, 2015 #1 Who is responsible for updating firmware on RNS 510, the dealer or the customer?
B BarryT82 Veteran Member Joined Mar 26, 2010 Location Charleston, WV TDI ‘12 JSW TDI Jan 10, 2015 #2 VW doesn't put out updates so it's all on you. Most people get them from Peter I believe.
T tdiatlast Top Post Dawg Joined Jan 21, 2009 Location Fort Worth, Texas TDI 2009 Sportwagen (boughtback); 2014 Passat TDI SEL (boughtback) Jan 10, 2015 #3 ...better tell us who Peter is...
B BarryT82 Veteran Member Joined Mar 26, 2010 Location Charleston, WV TDI ‘12 JSW TDI Jan 10, 2015 #4 If you have a 2014 it's probably up to date. Press and hold setup then select version.
A Al Fischer Active member Joined Aug 5, 2014 Location Clovis, California TDI 2014 Passat SEL Premium Jan 10, 2015 #5 2014 rns-510 I have: H21 hardware I think it is a J version SW 4369 Map 3963 However the map version indicates 2012 map. ON 2014?? BS and nothing actually works poperly except the RADIO!! Who is Peter?
B BarryT82 Veteran Member Joined Mar 26, 2010 Location Charleston, WV TDI ‘12 JSW TDI Jan 10, 2015 #6 I have the update you need for your version J. Your map version is 7963. There have been four updates since that one I believe.
A Al Fischer Active member Joined Aug 5, 2014 Location Clovis, California TDI 2014 Passat SEL Premium Jan 11, 2015 #7 Firmware What version firmware do I need? How can I get it?
B BarryT82 Veteran Member Joined Mar 26, 2010 Location Charleston, WV TDI ‘12 JSW TDI Jan 11, 2015 #8 I sent you a message yesterday with a link to download it.
A Al Fischer Active member Joined Aug 5, 2014 Location Clovis, California TDI 2014 Passat SEL Premium Jan 11, 2015 #9 Version? The unit shows: DELIVERY PART NUMBER 360035684J Does the "J" there indicate a J unit? It also says HW H21
A Al Fischer Active member Joined Aug 5, 2014 Location Clovis, California TDI 2014 Passat SEL Premium Jan 11, 2015 #10 Downloaded.. I just downloaded it and it looks good. (mounted it and looked at the layout) What is the procedure to do the update? Why doesnt the DEALER do this?
B BarryT82 Veteran Member Joined Mar 26, 2010 Location Charleston, WV TDI ‘12 JSW TDI Jan 11, 2015 #11 http://forums.tdiclub.com/showpost.php?p=4710477&postcount=36
LokiWolf Veteran Member Joined Apr 21, 2008 Location Richmond, VA TDI 2013 Passat TDI SEL Jan 11, 2015 #12 Again, lets keep the 510 discussion in one place. http://forums.tdiclub.com/showthread.php?t=396449 Read the first post in the thread. FYI - Peter is ExtremeNetwork, and one of if not the only Continental Radio dealer in the US.
K kalel1o1 New member Joined Apr 28, 2021 Location Canada TDI Passat Apr 28, 2021 #13 BarryT82 said: I sent you a message yesterday with a link to download it. Click to expand... I know it's been a few years but I need this link too
