Old April 15th, 2018, 19:38   #1
VWFan915
Post 2006 Jetta TDI alternator replacement
Does anyone have any information on how to replace the alternator on a 2006 Jetta TDI?
Much appreciated!!
VWFan915 is offline   Reply With Quote
Old April 16th, 2018, 07:34   #2
Metal Man
Metal Man's Avatar
Other than removing the belt from underneath the car it would all be done from above. They didn't get much easier, just remove a hose and maybe the fuel filter to make some room and then it's just a couple of bolts. I have rebuilt Bosch in stock.
For parts and timing belt tool rentals www.metalmanparts.com FREE shipping on most orders over $75.
Metalmanparts Facebook page
https://www.facebook.com/metalmanparts
Metal Man is offline   Reply With Quote
Old April 16th, 2018, 09:12   #3
oilhammer's Avatar
Fuel Economy: fantastic
You can get the BRM's accessory belt off and back on from above, this is a pretty easy alternator.
Remove the charge air tube, fish it out from under the fuel and coolant hoses.
I swing the fuel filter assembly up and out of the way (no need to remove any fuel lines). Three 10mm fasteners.
Pull the tensioner up into service position and slip a pin in the hole to hold it in place.
Take the belt off... honestly cannot remember if you need to remove the tensioner to get at the alternator bolts or not on the BRM, but if you do, pretty easy, just two bolts, then the two alternator bolts, slip it up, make sure the battery is disconnected, then remove he wires and holder on the back side of the alternator.
Really easy job.
I would only replace it with a Bosch unit, and with a new INA pulley if it does not already come with one (it should, though).
www.cardocautomotive.com
Old April 16th, 2018, 10:58   #4
banshee365
TDI(s): '13 Passat
If one needs to ask how to replace an alternator it is worth mentioning that the battery needs to be disconnected first.
banshee365 is offline   Reply With Quote
Old April 16th, 2018, 11:22   #5
oilhammer's Avatar
Yes, true. I do them "hot" because I know how to do it, and have a trick... You can also just remove the lead from the alternator at the fuse link box, too.
That way all the keep alive memory in the car stays put.
Old April 16th, 2018, 13:26   #6
Henrick
The tensioner doesn't need to be removed. I can manage to do everything from the top on an engine very similar to BRM (we don't have BRMs on this side of the pond).
I also don't disconnect the battery since it loses some adaptations (e.g. trip mileage, clock, window adaptations). Once I undo the positive lead from the alternator, I put a cap on it and ziptie it to the plastic dipstick tube.
Henrick is offline   Reply With Quote
Old April 19th, 2018, 00:19   #7
Ol'Rattler
Ol'Rattler's Avatar
Did you check the clutched pulley on the alternator? If it is slipping it will cause a no charging situation.
  • Remove the serpentine belt.
  • Block the alternators internal fan with a screwdriver.
  • Try to turn the pulley both directions by hand.
It should turn freely in one direction and not turn in the other direction. if it turns in both directions or doesn't turn in either direction replace the pulley. This can be done withe the alternator still in the car.
https://www.idparts.com/alternator-p...k6-p-1118.html
https://www.idparts.com/alternator-p...ew-p-6283.html
The other possible problem is the Brush/regulator assembly which can also be replaced in the car providing the bearings and the slip rings are O.K.
https://www.ecstuning.com/b-bosch-pa...021545806~bos/
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Alternator replacement 2000 Jetta TDI sgnhis TDI 101 12 March 25th, 2018 20:36
2001 A4 Jetta TDI Alternator Replacement gbillman VW MKIV-A4 TDIs (VE and PD) 23 August 14th, 2015 14:21
2006 volkswagon jetta tdi alternator regulator testing snider TDI 101 3 January 30th, 2012 23:26
2006 Jetta replace alternator pulley or alternator? uhale VW MKV-A5 Golf/Jettas 12 July 10th, 2011 10:50
Alternator replacement on 2002 Jetta TDi mshook TDI 101 8 February 13th, 2010 21:29
Page generated in 0.13720 seconds with 13 queries
[Output: 81.23 Kb. compressed to 70.62 Kb. by saving 10.61 Kb. (13.07%)]
