Old April 4th, 2018, 00:08   #706
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
300-325Whp will be difficult with a compressor upgrade only....
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old April 4th, 2018, 03:07   #707
X-Man
X-Man's Avatar
Originally Posted by yrktreg View Post
Thank you sir!
How laggy will this be with the V6 3.0?
I don't think you will notice much of a difference in spool especially after remap
TDI turbochargers for less
turbos@xman750.co.uk - GTB1756vk, GTB2260vk, 1.9TDI hybrids and more...
www.facebook.com/XMan-Turbos
X-Man is offline   Reply With Quote
Old April 5th, 2018, 18:56   #708
yrktreg
Any best guesses with just a compressor upgrade?
I'm not up on 3.0 stuff so that was just a guesstimate number..
yrktreg is offline   Reply With Quote
Old April 5th, 2018, 18:56   #709
yrktreg
Good to know, thank you sir.
Old April 16th, 2018, 07:18   #710
mirrco
Fuel Economy: 4.06
hello, Please who have dimensions: Compressor housing GTB2260vklr?
My GTB2260VZK:
Compressor housing have 135mm outher diameter, and inner dia 108.4mm.
Turbine houning: outher 140.2mm and inner 124.1mm
Thanks a lot for gtb2260VK and gtb2260VKLR!
mirrco is offline   Reply With Quote
Old April 18th, 2018, 18:52   #711
Motohead1
Im looking for the turbine wheel specs for a bv43a. I found the compressor specs in this thread at 37mm inducer and 49mm exducer but caint find anything on the turbine side. Any help would be appreciated. Thanks.
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old April 18th, 2018, 20:20   #712
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Which bv43a? There are various types....
Old April 19th, 2018, 06:36   #713
Motohead1
Ahh did not know that. The PN is 5303988010. Its the KKK version that bolts up to a AFN manifold.
Dodge Dakota QC Tdi
Old April 19th, 2018, 13:03   #714
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
You mean 5303 988 0109 do you?
Compressor wheel is
Inducer 37mm
exducer 48.6mm
tip height 3.6mm
5+5 blades
Turbine wheel
Inducer 42.9mm
exducer 38.1mm
tip height 7mm
9 blades
Old April 19th, 2018, 19:28   #715
Motohead1
Compressor wheel is
Inducer 37mm
exducer 48.6mm
tip height 3.6mm
5+5 blades
Turbine wheel
Inducer 42.9mm
exducer 38.1mm
tip height 7mm
9 blades
Yep forgot the 9. Thank you so much. Yea I need a bigger turbo.
Dodge Dakota QC Tdi
Old April 21st, 2018, 23:16   #716
yrktreg
A little off topic, but what is the groups thoughts on ceramic ball bearings for the GTB2260?
May be doing a rebuild when adding a larger compressor wheel.
Good upgrade, or skip?
Old May 2nd, 2018, 13:54   #717
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
AFAIK, ball bearings are not drop-in replacements where journal bearings were originally used.
Old May 2nd, 2018, 13:56   #718
Rub87
not really no .
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old May 10th, 2018, 07:33   #719
IonutTurbo
IonutTurbo's Avatar
Default Opel Bi Turbo / Honda Bi turbo / Vw 1.5 TSI with VNT / Toyota 1.4 D4D
If someone needs info about this turbos please let me know
Opel 1.6CDTi Bi-Turbo 160 from 2015
Garrett Part Number 843059-5004S
OE Part Number 55497919 OE
Turbo Technology Dual Stage Actuation 4 Actuators
Model DSGT1752S + GTD1038VZ
________________________________________________
Honda 1.6i-DTEC 160 from 2015
Garrett Part Number 832637-5003S
OE Part Number 18900R5ZG025M2 OE
Turbo Technology Dual Stage Serial - Actuation 3 Actuators
Model GT1549S + GTD1038VZ
Vw Golf 1.5TSI EVO 130 from 2017 :
Garrett Part Number 847009-5006S
OE Part Number 05E145701E OE
Direct Service Replacement -
Turbo Technology VNT
Actuation Electric
Model MGT1241VZ
Toyota 1.4D4D from 2015 -
Garrett Part Number 834081-5003S
OE Part Number 172010N070 OE
Actuation Electric
Model GTD1241VZ
https://drive.google.com/open?id=1in...I13T-LhKAwjSic
Turbo Size Matters !
IonutTurbo is offline   Reply With Quote
Old May 11th, 2018, 19:34   #720
adamss24
Fuel Economy: 35-45mpg
Does anyone have specs for the Bmw turbo as fitted to the 740d ? Went to local breakers and they had a few tasty turbochargers on the shelf, the one I am asking was a huge housing with billet compressor and had v-band exhaust housing ! Price was steep €500... it looked big for a single turbo ! They also had the twin turbo from the same model... that looked impressive- also Garrett jobbies !
adamss24 is offline   Reply With Quote
Page generated in 0.17452 seconds with 12 queries
[Output: 124.85 Kb. compressed to 103.71 Kb. by saving 21.14 Kb. (16.93%)]
