DubProblems
What are the most common deletes on a PD? What sensors can be deleted if any. Keep in mind this car will be a fun weekend car, not a daily. These are the sensors/equipment I know of, some I know can be deleted some not.
EGT, 100% can delete
ASV, 100% can delete
O2 sensor, 100% can delete
Sensor on timing side, assuming cam pos sensor
Crank position sensor
fuel temp sensor, can this be deleted and set to a static value?
MAF
MAP
Oil temp/pressure, can never remember which it measures
Coolant temp sensor
N75
BHW might come OEM with an EGT sensor?
I'm sure I am missing some. Again, I am trying to make this car/swap as simple as possible and was wondering what sensors are required for the car to run.
MAF
MAP
Coolant temp sensor
N75
