Ughhh...after a test drive, the hesitation at around 2,000 rpm is still there (under acceleration) but only happens randomly.
Any suggestions what to do next?
The turbo plumbing is tight, timing it dead on, car pulls hard and idles fine.
I have also cleaned the injectors with Diesel Purge,
Checked all vacuum lines,
Checked vacuum at the N75 (~ 24" Hg) at idle.
What has not been done is sending the injectors to Drivebywire for cleaning/testing,
Checking the turbo actuator. (not sure this will be easy to do in the car)
