grounds in trunk 06 tdi jetta brm engine
fluxcore
ma.
06 jetta tdi
Could some one Please inform me to where the grounds are in trunk, so i remove the carpet for the proper area. Thanks
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2012 wagon CJAA; 2004 wagon BEW
What do you want to do?
The license plate lights get their ground from the trunk lid itself via screws. The power plug has a big dedicated ground wire.
fluxcore
ma.
06 jetta tdi
the trunk lid, fuel door,roof window, wiper and washer,door lock,don't operate all fuse were good. i wan't to fix PLEASE thank for responding Jim
sudhir saxena
Mrakham, Ontario, Canada
2011 Golf TDI, DSG comfortline, 2009 Jetta 2.5 High line
Based on the issues you have mentioned , I suspect problem lies with driver side door wire loom going inside the body. More knowledgeable will respond further.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Did a little searching, coldn't find a good match. They might be behind the side panels.
