At this point, I dont believe I'm pulling the head.
Reason being... According to the timing marks and slot on the cam, the two were still in time. Pulled the valve cover and lifters and inspected them very closely... no impact marks or damage. Inspected the valve tips... no impact damage. All of the valve tips are sitting at ~the same level.
From everything I've read and seen, there should be CLEAR signs of impact if the cam jumped time but there are none.
The timing belt was completely in tact... no teeth missing.. could definitely tell it was running on a busted gear as there is some wear. Also, the belt was still tight when I took it off. The only thing keeping the water pump from going completely crazy is where the impeller rides in the housing not allowing the gear to move too much.
I wish there was a way I could guarantee that there was no damage done without pulling the head.. everything is pointing to no damage done.
My gut says to run it... but I'm still questioning that. Strongly debating if pulling the head is worth it...
