Hi everyone,
Been searching for the last few days in this forum (as well as a few others) for my specific problem but I don't think I've found my exact case...
I noticed some oil on the ground where my wife usually parks her Jetta (2005.5 w/ about 100k by the way). I checked the oil level but it was still reading near full on the dipstick. I had done an oil change about a week or so prior to noticing the oil so I inspected the oil filter cap area for leaks. I found that the o-ring had been pinched and cut so I figured that this was the problem. After replacing it, I let the car run for a while while watching that area for leaks and didn't see anything after about 5-10 min. That evening I noticed another small pool of oil, which makes me question if that was the "only" problem.
I've also noticed some oil on the lower rear part of the fan near what I think is an electrical connection. I've read a few times that there's an oil cooler in that general area but didn't see anywhere that it might be leaking onto that spot. Can anyone shed any light on that for me? I've noticed this "leak" for the last year or so but have been monitoring the oil level and there isn't really any noticeable drop in level between oil changes.
Either way, if the oil filter o-ring leak has been fixed, then this other leak has gotten worse and I need to know exactly what's involved...
Thanks!
Thanks!
