Turbosprezarka
- Joined
- Feb 1, 2006
- Location
- New England
- TDI
- 2001 Jetta TDI (ALH) GLS, 5sp, Tornado Red, 301,593 miles, SOLD
Hello all. I have a 2001 Jetta ALH TDI with 83,000 miles. Recently I've begun to notice that at least every other day when I get in the car and begin to warm the engine up, the coolant temp gauge on the dash gauge cluster is sporadic. Meaning sometimes ill drive around and it will read zero, then suddenly go to full temp. Or it can also start moving up then stop, then move down, and fluctuate like that. This has happened only 1 other time, about a year ago to date.
If you go to Measuring Blocks, Group 7, it displays fuel, air, and coolant temp. I would think that if you left the car outside overnight, all three of these values should be equal to the ambient air temp, within some manufacturer’s tolerance. I’ve checked these values periodically since I first had this sporadic coolant gauge issue last year and this is what I witnessed. Fuel and coolant temps are usually close in value, but air sensor temp is usually around 5-10 degrees Celsius less. Today for example, my car had been shutoff for 6 hours in constant 28F degree weather. I logged into Vag-com before starting it and the readings were actually as follows (converted to F):
Readings in the past have been similar.
I’m going to replace the coolant temp sensor anyways, since at least the sensor portion that displays temp is shot. But has anyone ever read these values in cold weather (40F or less)? Would anyone be willing to take a log of these before starting one morning, and reporting back?
I just don’t understand why:
1. All three aren’t equal?
2. Why fuel and coolant are equal but not to air?
3. Why none are the actual ambient air, even the charge air sensor reading (which is not being boosted with the car off, so it should be equal to ambient?
4. Could this be contributed to hard starting if the coolant temp sensor is reading way above the ambient air like this?
Fuel
Air
Coolant
Which is with the car outside for these 6 hours, not in a garage. Air
Coolant
57.9F
40.1F
57.0F
