JettaTDIBlack
Can you use an oil pan from an ALH Gas model on a TDI?
dubrs.com
dubrs.com
I am asking which MK4 oil pans can be used on a MK4 Jetta TDI.Um, no such thing as an "ALH Gas model", far as I know.
Are you asking about 2.0, 1.8T, or VR6 oil pan?
I noticed on all of the non TDI models on the junkyard today that they have a metal cover like on the tranny. Can that cover be used on a TDI?A gas 2.0l pan would be the same. A 1.8T pan would work, but you would have to block off the turbo oil return opening.
Could you use a 1.8 pan and use the turbo oil return to plumb up a CCV catch can drain point?A gas 2.0l pan would be the same. A 1.8T pan would work, but you would have to block off the turbo oil return opening.
Do you mean a skid plate? I love mine, never have to worrry about bottoming out in potholes. I probably have a few 10 mil sockets sitting on top of it thoughI noticed on all of the non TDI models on the junkyard today that they have a metal cover like on the tranny. Can that cover be used on a TDI?
dubrs.com
Yes, the skid plate. Had a brain fart. Still wondering if it can be used on a TDI. If not, what the hell VW.Do you mean a skid plate? I love mine, never have to worrry about bottoming out in potholes. I probably have a few 10 mil sockets sitting on top of it though
Depends. I have one on mine but I don't know what brand it is. But I'd highly recommend, its very cheap insurance on all your expensive stuff down thereYes, the skid plate. Had a brain fart. Still wondering if it can be used on a TDI. If not, what the hell VW.
Oh, I have lost a few 10mm sockets in the junkyard.
dubrs.com
Yes. I'm not sure since I didn't have a TDI in the yard to compare it to the gassers. But, I checked on my engine and it seems to have the same mounting points for the oil pan skid plate (cage) as the gasser version.Your talking about one that just surrounds the oil pan? I would imagine it would take a lot of cutting because of the A/C compressor mounting on an ALH.
Crap, that's not good. I was going to get one soon and see if it fits. All, but one of the ones in the yard still had their black paint on them, and the one that didn't just had a scrape or two on it.I have seen those metal protector plates bend up and crack the pan.
How about a hybrid pan?
https://www.europaparts.com/engine-oil-pan-06a103601t.html
I replaced my pan last night and you're right, even though the engine has the mounting points, it looks like the compressor would get in the way.Your talking about one that just surrounds the oil pan? I would imagine it would take a lot of cutting because of the A/C compressor mounting on an ALH.
