thilton59
Background:
2015 Jetta TDI, DSG, stock, 22k miles
Problem:
Transmission will not go into any gear. "P" warning light flashes on dash. All fusses are intact. Investigation led to discovery that shift assembly connector is detached (see pictures).
https://instagram.com/p/BqTQKSNlMwv/
4 pics total(this is the view under the shift boot)
Information Requested:
I can not reconnect the aforementioned plug. The pins are intact and there is no obvious damage. I need to know how to get this connector to snap into place; the male and female connections are able to get to know each other, but it seems they don't want to be exclusive and thusly won't snap together in mechanical matrimony.
Futhermore...:
I've been through it with the dealer, they won't cover it under any of the warranties I have and my incessant meddling has earned me a persona non grata. So let's not go down that road, or even in that general direction(which is south, into the lowest circle of Hell, which is where the Hendrick Motors owned VW of Murrieta has there business office.)
Also, this is my first automatic and I've had it all of 4 months, suffice it to say, bad luck comes in 3`s, and losing a job and a girl only leave a car to go wrong. Womp womp...
Problem:
Futhermore...:
