Jolly
We finally made the decision to keep the A5 Jetta instead of selling it back to VW right away. Aside from some of the other issues I need to resolve, the clutch "chatter" is likely the biggest most expensive one to fix.
Car has 6-speed manual with about 140,000 miles. The clutch has been making noise for a year and half - mostly while at idle and in neutral. Car still seems to drive fine, maybe a little difficult to shift gears, but nothing major. In the past month its gotten significantly noisier, if I hold the clutch half way out just before it begins to grab, it makes a bunch of noise. Noise goes away and returns with its normal rattles with the clutch out all the way.
A straight forward diagnosis would indicate its likely a throwout/release bearing. But I keep reading about the dual mass flywheel failing which creates similar symptoms.
Anyone have experience with these transmissions (I believe its an O2Q). Is the noise likely to be the DMF, or the release bearing? I've priced full replacement kits with a SMF. Based on what I have read, this seems like the SMF is the preferred option for replacement. Any big differences to expect? The Valeo kit from ID Parts the way to go with this?
