I'm in Chicagoland and they are nowhere close to mint, full of potholes is a best description
I have 235/45R18 stock for now and winter have blizzaks 225/50 on stock wheels, I'm sad but will pass on 20's , have no patience to replace things for stupid decisionsforget 20's, 19's, 18s, even 17's at stock diameter are sketchy IMO, 17" with 60-65 series sidewall would be really cushy. Its only a matter of when not if a pot hole or raised expansion joint is going to blow out the sidewall/stove up the rim.
Best part of winter is rolling on 215-60-16 snow tires, next set I'll prob go up to 215-65-16 just cause.
Consulted with the Boss and she says Bugatti as a daily is not an option at this timeadded side wall is never a bad thing,
if you want the look of larger wheels may i suggest you take the Bugatti approach and just paint the tire? I mean if a 19mil car can pull it off so can your midsize daily beater.
https://www.cnn.com/2019/03/05/success/bugatti-la-voiture-noire/index.html
Don't think I'll go that far as I'll be getting a sway bar for better handlingChanged from stock 235x45x18 a year ago to 235x55x18. Best thing I done. Slightly larger tires give much better cushioning then stock tires.
I wanna go 245 this summer.Changed from stock 235x45x18 a year ago to 235x55x18. Best thing I done. Slightly larger tires give much better cushioning then stock tires.
