Old September 22nd, 2017, 02:43   #31
Sheppy
Keep it up man really cool results, whole car not just the engine
Sheppy is offline   Reply With Quote
Old September 22nd, 2017, 03:57   #32
ryanp
ryanp's Avatar
Because I'm not an idiot or a troll.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old September 25th, 2017, 04:24   #33
numbnuts
TDI(s): mk2 golf
Hi Ryan,
Think we spoke about this before but Why not use DSG? This will surely make a low 9s car, have you seen the results the Adrenalin tuning mk1 golf has with DSG?
current daily mk2 golf with PD swap, with o2m, LSD, 2260vk, bosio race injectors, darkside race cam = 283hp & 415lbft
to come.....mk1 swap and N2o=
Passat B5.5 tdi daily beast
numbnuts is offline   Reply With Quote
Old September 25th, 2017, 05:20   #34
84 GTI
TDI(s): 2001 Jetta
Amazing progress, keep up the good work!
Do you find that your valve cover vent dirties the intake side of the turbo, intercooler and intake piping? Just wondering why you opted this method vs a catch can or an exhaust vent?
84 GTI is offline   Reply With Quote
Old September 26th, 2017, 19:11   #35
Sheppy
Interesting question, I'm glad to see no catch can
We don't have another crank vent like 1.8T engine, our vacuum pump also pushes pressure into the crank case. My opinion is to not restrict the crank case vent in any way, I don't know how restrictive catch cans are, so I don't use one.
I wonder what Ryan's thoughts are though, because I've always wanted a second option
Old September 26th, 2017, 22:20   #36
[486]
TDI(s): 02 golf ALH
catch can doesn't have to be restrictive in any way, it's just a can with a rag stuffed in it to condense vapours, and the vacuum pump exhaust flow is insignificant compared to normal blowby at 5k rpm and 40 psi
it is extra weight that a drag car doesn't really need
I'd imagine it's dumped in the intake so it doesn't drip on the track, which'll get you kicked out.
[486] is offline   Reply With Quote
Old September 27th, 2017, 05:07   #37
84 GTI
TDI(s): 2001 Jetta
So why not just plumb it into the exhaust and avoid getting oil mist in your intake system?
Old September 27th, 2017, 08:00   #38
ryanp
ryanp's Avatar
We are thinking of DSG for next year. We have a DQ500 test car to play with over the next few months. I'm not sure if it's worth the weight penalty compared to a DQ250.
We tested the CCV to exhaust and we had positive pressure, I think only NA cars scavenging effect is strong enough.
Even just a hose to atmosphere gives too much pressure at high boost / Rpm, plus drag strips like to see a can!
Oil has a decent Cetane value anyway and there is no downside to lower case pressures so we pull as much as we can out.
Old September 27th, 2017, 10:39   #39
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
How strong can the dq350 be? i know Dq500 can take 1000+ Nm with proper software and clutches, about 100kg of weight.
Since i remapped it 3 weeks ago the dq500 goes much better.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old September 30th, 2017, 08:25   #40
eddie_1
eddie_1's Avatar
aye, winowt takenowt.
Only was a problem in combo with EGR soot.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old October 6th, 2017, 19:15   #41
2footbraker
2footbraker's Avatar
That engine in a mk1 body would be my dream 4 cylinder tdi!
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old July 2nd, 2018, 03:10   #42
ryanp
ryanp's Avatar
Had this out last week, managed 165mph in the 1/2 mile on low NOS then killed 4th gear. We are going to another event with 1/2 mile in a month or so.
Old July 2nd, 2018, 08:59   #43
Jetmugg
TDI(s): None
Amazing work there! If you ever decide that you want to run at the Bonneville Salt Flats for a land speed record, please hit me up. I have a record-holding diesel truck entry (completely SCTA compliant with log bood) that's already set up for VW power.
Steve M.
Jetmugg is offline   Reply With Quote
Old July 2nd, 2018, 23:03   #44
Macradiators.com
Good to know the engine lasts the 800m pull.
CP3 Upgrade
Old July 4th, 2018, 23:49   #45
adamss24
Fuel Economy: 35-45mpg
Really good work there Ryan ! Keep breaking records and pushing the boundaries !
adamss24 is offline   Reply With Quote
153mph Darkside Volkswagen Jetta TDI - 146mph Standing Mile ryanp TDI Power Enhancements 35 January 3rd, 2013 17:09
Common Rail TDI Heater Kstjarre_TDi TDI 101 11 January 16th, 2011 06:38
2.0 common rail tdi enhancements! tdipower4me TDI Power Enhancements 11 October 13th, 2006 13:05
Honda Common Rail TDI dieselmeister TDI Fuel Economy 25 January 15th, 2003 17:52
Honda Common Rail TDI dieselmeister TDI Fuel Economy 4 December 30th, 2002 11:32
Page generated in 0.12316 seconds with 11 queries
[Output: 129.18 Kb. compressed to 107.89 Kb. by saving 21.29 Kb. (16.48%)]
