Genesis
First, history and current.
Car is close to stock but had a set of larger injectors (.205s I think; was full injectors, not just nozzles) put in at ~30k miles and has been "just driven" since. Original MAF still reaches over 900 no problems, no flat spots in the acceleration, original turbo and clutch. No problems (yet) with the fateful DMF rattle; I can detect a bit of throwout roughness though, so eventually I'm going to have to drop the transaxle. Currently 155k (miles) on the clock. The car is notably faster than my friend's sedan that is bone stock (and has been providing lots of smiles the entire time.) EGR is turned down via adaptation but still connected and build-up is there but not enough for me to pull the intake; there's no notable problems with airflow.
Timing belt replaced twice, last time about 10k ago or thereabouts (full kit, including all rollers and water pump) by myself. Timing is set right near the upper boundary. Current injector balance looks like this fully warmed-up:
One outlier in #4 but it's not horrible. No driving or operational problems. Engine is quiet, smooth and runs great. I can provoke a bit of smoke under the right atmospheric conditions and hard acceleration but it's more of a haze than smoke.
I was going to give the car to my kid for her 16th birthday and had been thinking that for the last couple of years, which is (mostly) why I hadn't done anything more to it. The problem is that I'm unable to find anything I like better to replace it with never mind that it still looks (inside and out) and runs damn good for a 10 year old car, so guess what - I'm keeping it and will find something else for her. Rear shocks and such are on the menu soon along with a bunch of minor stuff, then it gets fun.
I couldn't resist the "tacotaco" SMIC on eBAY at his price, and bought and installed that. It made a notable difference in IATs, especially at cruise and a bit of a difference in power, especially in the midrange (I'm going to back and check the stock intercooler I have on my shelf; it might have had a slight leak -- or it might just be the better charge cooling, given that I am in Florida and it's damn hot right now.) Now I'm thinking that (1) I'm probably going to find myself on the wrong end of a DMF problem eventually and (2) once I do the door is wide open.
So my thoughts are this:
1. Stick DLC 1019s in there; while the car has no operational problems at present I have no clue what the pattern looks like on the injectors, and they do have 120k on them. Play hot-swap and be done with it; I know my current injectors are working ok as the car's running fine so there should be no core issues. Looks like I can do that including balancing for about $500 (after the core is returned.) Have those set for "Flow 2" ("low smoke for tuned vehicles") in anticipation of....
2. When the DMF craps (or if I do #3 and "make Sachs cry") replace the clutch with a South Bend Stage II "Daily" to get me up to ~325ft/lb of torque holding capacity. End of potential clutch issues which leads me to....
3. Put a Malone or Kerma tune on the ECU, probably Stage II. If/when the stock VNT-15 dies consider the 17/22 upgrade as a replacement. I already have the SMIC upgraded but would need to improve the piping; there's a reasonably-inexpensive kit available for that intended to work with the 17/22 however.
I suspect that Nozzles + tune means I smoke the stock clutch, which is why I didn't do the tune a long time ago -- and I've gotten away with the nozzles now for 100k+ miles, so it appears that path "worked" and yet has provided me with a very nice bump up in performance without any sacrifice in drivability.
Thoughts? With a stock ECU am I going to get anything beyond the .205ishes that I have in there now or am I basically buying refreshed nozzles on a PM basis at this point?
