csb
- Joined
- Mar 9, 2013
- Location
- minneapolis
- TDI
- 2000, 2001, 2002, 2003 Jetta TDI's, 2000 Golf TDI, 2005 Passat TDI
I'm an import mechanic, however, my experience with diesel motors is a work-in-progress. I recently purchased an ALH Jetta that will crank normally but will not start. I was told by the dealer who took it in on trade (a VW dealer) that is had "no compression in the cylinders". The timing belt looked good upon visual inspection which I realize doesn't mean much. No immobilizer/key issues, no stored codes (checked with RossTech), fuel is at the injectors, etc. I am used to gas engines having a very "unique" sound when they have low/no compression and turn over. This ALH sounds just like my other ALH diesels, though. I have NOT performed a compression test yet but that is my next plan.
