Monkey1
I only have USB connection on my new laptop and want to get into Vagcoming my own car. Seen the ones on e-bay but not sure which ones are the good ones.
Thanks for the info
Thanks for the info
I bought one of those E Bay USB cables and it didn't work.To add insult to injury,the seller wouldn't reply to any of my e mails looking for tech support,or a refund.(I won my PayPal fraud case against this guy)Monkey1 said:too much $
Just buy the OEM and be done with it. Read the many "EBay cable" stories and you'll most likely decide not to "F" with the generic/aftermarket ones. Think about who spec.'ed out the OEM cable.....Ross-Tech . - Sloppy SnoodMonkey1 said:too much $
Depends what you're looking for. If you want the latest software, upgrades to future versions, and full support for your system from the moment you receive it, you buy a Ross-Tech interface.The ross tech cables appear to be a total ripoff.
DieselSmoker said:I had an aftermarket cable for vag-com for my last tdi. Wish I hadn't of sold it. I think it was like $40 or so, and it worked perfectly. The ross tech cables appear to be a total ripoff.
I second that. I would have paid $1000 for VAG-COM with no regrets. I personally can't believe they sell it so cheap.40X40 said:Ross-tech is a bargain!
Bill
Last time I checked this wasn't a high roller Mercedes Benz forum so cost has always been an issue. Also, his profile indicates he doesn't own an A5.40X40 said:Sheesh, Buy the real thing.
How come folks are so cheap nowadays?
How come this thread comes back every month?
If you have an A-5 you need USB CAN-BUS, cheap knock offs of THIS model don't work.
Bill
We have some "whisper down the lane effect" here. We are indeed working on a less expensive CAN interface for the Mk.5 cars. But it won't be a "HEX", and it won't be backwards compatible with older cars. It will be USB only (no serial version). Planned introduction "in the spring" is still correct, but spring just started. At the moment it looks like June, but don't consider that an iron-clad promise.less expensive HEX-CAN version
Hi folks,mparker326 said:I have an aftermarket cable that works fine but it is a serial cable. I haven't heard of many aftermarket USB cables that work successfully. You could try alpha-bid on ebay. He will take it back if it doesn't work.
Older VAG-COM versions (up to 409) only use the OBD-II button on the main screen for generic OBD-II tests, this has nothing to with that fact if VAG-COM would work with that car. Try accessing control modules individually with using the "SELECT" button instead.Turbo Diesel-x said:So I tried to connect to my B4's ECU and the VAG-COM software said the car doesn't support OBD II standard.
You are right, this is a USB<>RS232 emulation, no real USB. All 3rd party interfaces work like this, so this is another problem with them since this emulation messes up the timing and leads to unstable/unreliable connections.Turbo Diesel-x said:Before that the cable was not recognized by VAG-COM, so the guy from Alpha-bid sent me the "pseudo" USB driver to make it work. It is kind of USB emulation since the cable only is recognized by VAG-COM if tested in 'COM3' serial and not in USB option.
You should at least contact the seller for support since it's their stuff you are using and they "should" know how it works. FWIW, most of the 3rd party sellers just get their stuff in a big box from China and re-pack it without even testing and/or knowing what it does and how to support it.Turbo Diesel-x said:...or I would be returning this piece of metal and buy a Ro$$-Tech cable.
I already told you I use a serial cable not a psuedo usb. I told you to try it and if it doesn't work get your money back. Either use a serial cable or send it back.Turbo Diesel-x said:Mparker326 please give me a help on this... or I would be returning this piece of metal and buy a Ro$$-Tech cable.
Help please !!
You don't think Ross-Tech makes money from this? Do you understand shareware? It is a tease to get you to buy the real version.BrentB said:Maybe Uwe should jsut stop offering the old version of vag-com and go after anyone who offers it on the net. it must be nice for all these companys to be making money on someone elses software. maybe everyone should start looking at it as buying software that comes with some free hardware.
Yes. You just have to make sure that your laptop has a serial port. Newer ones don't.simbolo said:Is it better to just get a 3rd party serial cable that is 409.1 compatible instead of a usb 3rd party one, will doing this avoid the USB<>RS232 driver emulation issues?
