2003 jetta 01M transmission. Almost 200k on the speedo. When traveling on the interstate I usually set my cruise at 75-80. Now in hilly areas I can no longer maintain cruising speed and the transmission is downshifting.
Now every time I start the car whether it is hot or cold sitting for a half hour or more, I have no power for a mile or so and an unresponsive throttle and then all of a sudden something kicks in and everything is back to normal for the rest of the trip. While it is in the unresponsive state it will gradually accelerate and shift but very slowly.
No codes are being set.
I replaced the air filter and fuel filter. I change the auto fluid every 50K and at 150K the fluid was good and no shavings on the magnet or bottom of the pan.
I'm stumped. Are the symptoms an indication of the transmission starting to fail? If so, I guess I'm looking at a new vehicle? Even though the body is in excellent condition I wouldn't want to put more than $1,000 into it to keep it running.
