Hello,
On my skoda octavia elegancefrom 2005, the instruction manual says that the right mirror should tilt downwards when selecting reverse gear.
It does not. Any idea if is is a missing coding ? But according to the manual it should do it.
I also have a skreeking noise from all the electric windows. On the right front side, there must be a lot of resistance, because sometimes the windows gos down on its own, as if there was a hand between the window and the frame.
Is this a known failure ? Can i grease somewhere and it will be better ?
Regards
Regards
