Gippeto
Spring has finally arrived in full force and my yard is no longer a muddy mess...yayyy!
Time to re-fresh the front end of the Jetta.
Plan is to replace everything at once that requres a front end alignment. I think I've got the parts figured out, but may be missing some small thing that I'll need to get the job finished...please let me know if I'm leaving something out. TIA
Lower control arms (left/right). These come with bushings and ball joints. Mevotech "supreme" w/limited lifetime.
Front strut assemblies. Come with upper mounts/bearings and springs. Monroe "quick strut" w/Limited lifetime.
Tie rod assemblies. Inner, outer and center section. Sounds like they come with boots for the rack, but will double check when I order. Mevotech "supreme" w/limited lifetime.
"Looks" like it should be a pretty straight forward job...."Looks"...lol.
Al
Al
