Hey Folks!
So i recently purchased a 2010 Touareg TDI (and by recent i mean last September )And i seem to have a problem i just cannot shake,
The Problem
Driver Door and only the Driver Door does not lock Electronically
The Circumstances
Lock the doors via the Fob, All doors except the Driver Door will lock, alarm arms. Driver door remains unlocked.
From inside the car, push any door lock button, again all doors except driver door lock.
If i drive and autolock activates, all doors except driver door lock.
The unlock function works perfectly fine.
Only way to lock the door is to stick the key into the barrel and do it manually.
The vehicle knows when the door is opened and when it is closed, MAF and lights concluded this.
What I've done so far
So I've done a complete auto-scan (logs attached) EDIT: seems i cannot post attachments... Look at the code
I've tried replacing the doorlock module... changed nothing
Check the wires in the door, and in the hinge rubber tube thing... all fine
You'll notice in the logs theres an issue with the radio.. i changed it for aftermarket android radio, comes with a canbus adapter... (not that it matters, had the problem since before radio change) I only mention this because some people said radio may be the culprit
I tried logging into the door and doing an output test... Communication error. cant connect to the door.
Also, there seems to be a dump truck of malfunctions with my vehicle, mostly all related to the central convenience and a data line... i honestly dont know what to do about that or how to fix it... not sure if everything is all related, or if i have multiple problems ... I dont know where to do from here. Any help would be greatly appreciated.
Thanks a lot for your time,
Jesse
The Problem
The Circumstances
Jesse
Code:
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 46 47 55 56 68 69
6D 6E 76 77
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
6E-Ctrl Head Roof -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (CAT) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 T HW: 7L0 907 401 K
Component: 3.0TDI EDC17G004AG 0090
Revision: 33H02--- Serial number: VWX3Z0I2903160
Coding: 0421002A590F0968
Shop #: WSC 94829 999 85859
VCID: 3C7144B27C1CCDFE88B-5000
1 Fault Found:
000564 - Boost Pressure Regulation
P0234 - 001 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 205499 km
Time Indication: 0
Date: 2018.03.26
Time: 15:33:02
Freeze Frame:
RPM: 2415 /min
Speed: 122.1 km/h
Absolute Pres.: 1326.0 mbar
Absolute Pres.: 2519.4 mbar
Absolute Pres.: 1030.2 mbar
Mass Air / Rev.: 1204.4 mg/str
Lambda: 85.2 %
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 LD HW: 09D 927 750 LD
Component: AL 750 6A 1569
Revision: 00H75000 Serial number:
Coding: 0004984
Shop #: WSC 31414 790 00001
VCID: 7BF387AE39920AC6C11-5000
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004354
VCID: 4685265A35D0872EEEF-8013
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 C HW: 7L0 909 135 C
Component: Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0I2903160
Coding: 0000232
VCID: 316F6586AC5E30962BD-8064
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 13
Reset counter: 46
Time Indication: 0
Date: 2018.03.25
Time: 16:37:28
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 0
Reset counter: 46
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0003030
VCID: 7AFD82AA31A833CEDA7-802F
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2004
Revision: -0004--- Serial number: --------------
Coding: A30008003F00BC000000000000000000
VCID: 80097042D774E91E143-80D5
3 Faults Found:
00061 - Footwell Lights
011 - Open Circuit - Intermittent
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7J0562889
Coding: 0000102
VCID: 3665569A413017AE7EF-8063
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 16
Reset counter: 159
Mileage: 188447 km
Time Indication: 0
Date: 2017.04.26
Time: 20:10:59
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 40
Reset counter: 119
Mileage: 203721 km
Time Indication: 0
Date: 2018.02.10
Time: 13:22:45
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__0B VW8T 0270
Revision: 92013027 Serial number: 003C600186G9
Coding: 0012354
VCID: 3B7347AE7E12CAC6811-806E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: J527 3601
Coding: 0010211
VCID: 43833F4E06E2B206C91-8016
1 Fault Found:
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 876 B HW: 7L6 920 876 B
Component: J285 KOMBI-INST. 9833
Revision: KHH05V44
Coding: 0004101
Shop #: WSC 44713 999 52438
VCID: 3B7347AE7A12CAC6811-806E
7 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 187
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:24
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:27
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:27
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 204586 km
Time Indication: 0
Date: 2018.03.15
Time: 14:43:31
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 16:37:26
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:14
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 876 B
Component: J533 GW-K-CAN TP20 9833
Coding: 77E2EF9BE3066002
VCID: F0E92082E3D4F99EE43-80A5
7 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Reset counter: 187
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:24
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:27
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 200060 km
Time Indication: 0
Date: 2017.10.17
Time: 17:18:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 204586 km
Time Indication: 0
Date: 2018.03.15
Time: 14:43:31
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 16:37:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:14
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No SW: 7L6 919 879 B HW: 7L6 919 879 B
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1439802T1DHN02
Shop #: WSC 00000 000 00000
VCID: 4685265A31D0872EEEF-8013
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:14
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 810F7546DB7EE0161BD-5000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: F7FB1B9E82BAAEA6259-80A2
3 Faults Found:
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
VCID: 4089304210F4A91ED43-4A3A
Subsystem 1 - Part No: 7L0 959 701 N
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 N
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
9 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
011 - Open Circuit
008 - Implausible Signal - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 B HW: 7L6 035 456 B
Component: 08K Audioverst. 0008
Revision: 00006000 Serial number: 00000008156092
VCID: 326D6A8AAD580B8E527-8067
4 Faults Found:
00419 - Left Front DSP Midrange Speaker (R103)
00870 - Bass Speaker Front Left (R21)
00421 - Rear Left DSP Midrange Speaker (R105)
00874 - Treble Speaker Front Left (R20)
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0143
Revision: 00H04000 Serial number:
Coding: 1290435
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000019
Address 56: Radio
Cannot be reached
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 397F5DA6702EF8D693D-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 101209 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A008002 Serial number: 00000124445892
Coding: 0016386
VCID: 3F8B33BE6A0AD6E6AD9-806A
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------049728
Coding: 0122110
VCID: 3A7D42AA7128F3CE9A7-806F
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 16:37:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:12
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000141608
VCID: 79FF9DA630AE38D6D3D-802C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 205294 km
Time Indication: 0
Date: 2018.03.25
Time: 17:10:14
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 397F5DA6742EF8D693D-806C
1 Fault Found:
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
