compu_85
Gadget Guy
I could stick them on my server, email them to perkins.jason at gmail
-J
-J
Great job.
Is the code flexible/extensible? Can we add code for auto mirror folding/unfolding ?
Best regards.
I will post the unlock instructions but they need to be tested first, so that is being worked on.
The auto mirror folding/unfolding may not be possible, someone else is working on it. I don't have any folding mirrors myself.
I am more interested in adding a feature to have the windows go down all the way with 1 touch(or maybe two) from the keyfob.
Well if others have cloned it that is out of my control, although I don't think it has been, I think they all come from the same guys in China.hi
the script can be copied just reading when vcds and enabling the locking bit again,
is just to find what is changed for every ccm revision,
I don´t see any trouble giving out the kvw100 script,
this device had been cloned and can be purchased on ebay easy,
I guess 90% of them are not original, also golf4 plataform is old, yes, old,
is a "old mod" only usefull for those of us keeping this car,
best regards
Invisible
I tried sending you a PM but I don't seem to be able to. The module you have only does the power doorlocks and sunroof so the auto window feature is not possible. The power windows you have are controlled by a different module from what I can tell.Great Job Steve!!!
I believe that all victims of blocked CCM´s without warning will be very grateful if you teach them how to recover access to his ccm.
I see nothing wrong with that, because the script can not be copied even reading it using vds. In any case those that play dirty are the KVW100 people when not warning.
My personal opionion is that it would be great if you publish how to recover ccm acces.
Have a great weekend, Agustín
hiWell if others have cloned it that is out of my control, although I don't think it has been, I think they all come from the same guys in China.
The bigger problem is that there is no universal script, it has to be modified to match each CCM.
There are several versions of the KVW100 code.hi
correct me if I am wrong, but same ccm with same reference can be write with a backup (cloned) and autoclose will be enabled,
all eeprom can be write, there is nothing like a serial number to play with,
even if wiring and programing motorola mcu will do the job,
best regards
Invisible
It will. Do you have VDS-PRO?Mega old thread I know but this is the only decent one regarding the KVW100 I can find...
I'm about to install one of these on my mk1 Seat Leon FR just as I did with my previous mk4 Golf but was wondering about the CCM been locked as I need to make a couple of adaptions (auto locks off & one touch all doors unlock) when my VCDS arrives in the post.
Will the KVW100 stop me making these changes and should I do them first?
Yes, you cannot modify things with VCDS like you can with VDS-pro. There are stickied threads in the Upgrade section that you should read.No I don't have VDS-Pro and tbh don't know much about it. Is it considerably different to VCDS then?
