BigCVids, the first TB change I did on my 2000 Jetta was done like you did it ....... by me. As at the time, I did not have the "proper tools" nor a Bentley Manual. And, down through the years with all my MK2 VW Rabbits, Jettas, etc., with the 1.5 and 1.6 diesel engines, that's pretty much how I changed the TB ....... never an issue!
Having said that, the correct way, is to pop loose the Cam Pulley and the three Injection Pump bolts (obviously TDC and locked in place) ... it makes the process so much easier to do.
Lastly, it is a very potential "knuckle skinning" procedure trying to "stretch" and work the TB onto the Cam and IP pulleys simultaneously........ and, if you miss it, well, you got to re-group and do it again!
