CrashedGolf
New guy here. I have a Jetta that I recently acquired. It will run with the mass airflow sensor unplugged. It will drive. But limp mode is triggered and it will barely run 60. If plugged in it will idle fine. But as soon as it’s shifted into gear (automatic) it runs for a second or 2 then dies. Slow to restart. Unplug it and it runs again in limp mode. The plug seems a little damaged, I have a replacement to splice in to try. I will update when I get a chance to do so. Just curious if this sounds like an expected behavior for maf/plug being bad.
