I have an 01 gold TDI with a 5 speed. It has injectors and a tune (can't rember who from sorry), egr elimination pipe, and a vnt17. Car has 190k on it. The car use to run amazing, black smoke and tires a spinning when put to the floor. I will admit that I ignored an intake/exhaust manifold gasket leak for a long time and drove it easy. I replaced the gaskets a couple of months ago and the car hasn't seemed to bounce back. Still spiking to about 20 psi on the gauge. Here is the od symptom.
When I run the car wide open throttle it runs ok, but as I lift on the pedal around a 1/4-1/2 throttle the car will have a surge of power more then WOT. The tune eliminated the check engine light for the EGR so I have no codes. Any suggestions as to what is holding the little monster back? I was thinking about starting with clening the MAF sensor. Any help would be appreciated
Thank you!
Thank you!
