Turbodude1
On my old 1999.5 Golf Tdi that I sold to a friend I am having an odd running issue.
Occasionally it sounds like it has a misfire and runs rough. While it is running like this the injector balance in block 13 is way off. maybe +- 1.8, however, sometimes the car will come out of it and the injector balance will be normal or have a variation of +-.5. Also when you rev the car up it puffs blue, but it doesn't smell like oil.
Any ideas what might be causing this? Car still has good power and isn't using a ton of oil. Maybe a quart every 4000 miles. Timing is on and the car still goes good at under heavier throttle. Is it bad injectors or a bad pump?
Thanks for any ideas.
