Has anyone checked to see what batteries are used in the new passat? here is a post from someone who worked for Johnson...
posted: Jan. 24, 2011 @ 11:15a
I worked for Johnson in the 80's... True, they are one of the 3 big battery makers. However, they manufacture batteries to different specs for certain high volume buyers, like
Sears/
WalMart/etc.
That being said, I always use Die Hard.
Sears is easy if you have to return/exchange for any reason.
I would recommend a few things:
1- Get the largest capacity battery that can fit in your vehicle. This is meaasured by 3 factors: CCA, reserve capacity, and discharge rating. Many companies do not provide discharge rating. The bigger numbers are better.
2- Maintenance Free batteries are usually a little bit more expensive, but worth the cost. Unless you overcharge them, they never need water added which is one of the biggest reason batteries fail. (Even if you add water later, damage has already been done to a battery that has had plates exposed.
3- If you make a lot of short trips, or the car sits for days at a time without being started, I suggest looking at the added cost to go to an AGM battery (DieHard Platinum, I think). These do not have liquid electrolyte... the have an electrolyte embedded into a fiberglass matting. They lose about 1-2% charge per MONTH compared to regular batteries which lose 1-3% per DAY. When a battery falls below 80% charge, it starts to lose lifespan. These batteries are also much better at handling vibration and have a lifespan of 8-10 years if treated properly!
4- If you run your battery low often (ie: listen to cd's at a campsite, use an inverter from your car, etc.) look into the AGM Marine battery (
Sears PM-1 or PM-2 I think). Same as the AGM auto battery, but with thicker plates so it can handle being run down then recharged with limited effect. Note that the warranty is lower on these batteries, but that is because they think you will be using it for a trolling motor... it is a slightly better constructed battery than the auto version (I think the die-hard marine batteries are made by exide, not Johnson).
Good Luck!
SteveG
