Ok, here's the short story:
Glow plugs don't work. It was about 39 degrees in N. Texas today. The car sat outside for 2 days and BARELY came to life after lots of cranking. I tried all the suggestions on this site, but I can't seem to get voltage to the harness.
Long story:
It's a 1999 Jetta, MK IV. The check engine light came on at 40K mi., when I lived in So. Cal. I determined the code was for the glow plug circuit. I didn't bother with a fix because I didn't need glow plugs in the warm climate. 80K mi. have since passed (w/ check engine light on). N. Texas gets cold now and then, so I need to get this fixed.
I've searched high and low on this forum for a fix, including the latest glow plug 101 thread--to no avail. I have replaced the harness and the relay. Haven't done the plugs yet, but one has infinite resistance, so I'll replace all if need be. I have also checked the fuse under the cover on the top of the battery for power. When I unplug the coolant temp sensor and check for voltage at the harness, I get nothing. Even despite a new relay and functional harness? Would one faulty plug cause the whole system to fail?
I'm about ready to install a manual switch to bypass the whole damn circuit, but I'm hoping something simple is happening. Thoughts? All I want is for the plugs to work. I don't care about the check engine light in particular. PLEASE HELP!
Long story:
