Old January 12th, 2018, 14:39   #1
relumalutan
relumalutan's Avatar
Default 06 Heated seats and HVAC blower issue
While driving home from work I have noticed that heated seats are not working and the HVAC blower is not working on the first setting. It works on the second, third and four. The funny thing is that it blows on the second setting with the force it used to blow on the first, and so on: it blows on the fourth setting with the force it used to blow on the third setting. Blower is not making any funny noises, it runs smooth. Fuses are OK.
Anybody has encountered such a situation?
Thanks.
relumalutan is offline   Reply With Quote
Old January 13th, 2018, 18:58   #2
Bob S.
The HVAC fan issue it typically the blower fan resistor. It is a common issue on these cars. The resistor is mounted by the blower under the passanger side dash. Search the subject. Speed 2, then 3 will be next to go.
On the seats: check the fuse & relay.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old January 20th, 2018, 18:10   #3
relumalutan
Installing a brand new battery solved the issues.
Electrical Problem - Signal lights, Blower, Rear Defroster, Heated Seats phaser TDI 101 2 January 3rd, 2016 16:19
06 jetta tdi heated seats questions 1ozzy VW MKV-A5 Golf/Jettas 6 October 18th, 2013 08:09
Heated seats issue caloony Ontario 11 May 15th, 2009 14:45
Heater blower and heated seats not working minnow VW MKIV-A4 TDIs (VE and PD) 1 April 11th, 2009 07:59
Hot issue - heated seats dee_zell TDI 101 9 April 22nd, 2008 17:27
Page generated in 0.10885 seconds with 12 queries
[Output: 58.35 Kb. compressed to 52.86 Kb. by saving 5.49 Kb. (9.41%)]
