Mr. Annoying
2005 Jetta GLS TDI wagon 5 speed
176K
In last 3 month
Replaced
Alternator
Both axles
Thermostat
Brake Master Cylinder
All 4 wheel bearings
Last year
1.8T clutch
Timing belt
Water pump
Summer tires 225/45/17 April
GLI front Brakes (312 mm)
Slotted drilled rotors front and rear April
Performance
VNT-17
Rocket chip RC2+
Whitbread stainless down pipe 21/2 inch
EGR delete
Top pipe retainer and new top hose
I also have a bunch of loose parts
Snow tires on 16” steel rims
Another set of summer tires on LeCastallet wheels (V6 Jetta)
Note the driving lights work with high beams and fogs with low beam
Stock Cat converter
Aftermarket cat new in box
I have been crazy about maintenance, oil changes with the correct oil between 5k and 7k, I was going to go to keep her to 300k but I got a good deal on a Golf sportwagen
the car is in southern CT and I would not hesitate to drive it cross country
pm me here with your Phone# and name
pictures to follow
Asking $6500
176K
In last 3 month
Replaced
Alternator
Both axles
Thermostat
Last year
1.8T clutch
Timing belt
Water pump
Performance
VNT-17
Rocket chip RC2+
EGR delete
Stock Cat converter
pictures to follow
Asking $6500
