NathanD
- Joined
- Apr 10, 2001
- Location
- Des Moines,IA
Last weekend traveling back to Iowa from a family reunion in Minnesota at 9:00 p.m. on Sunday, I had my first breakdown. Just 15 miles after passing the 80,000 mile mark my coolant light came on - red,blinking and beeping. I was about a mile from the next exit so I flipped the heat on high and nursed it to offramp..
The engine was running very rough and I smelled the sickly sweet smell of coolant. I shut the engine down immediately and opened the hood. The expansion tank was empty and the bottom of the engine was wet. Luckily I was only 8 miles from the dealership in Albert Lea, Minnesota, and was towed there within a half an hour..
The diagnosis the next morning: failed water pump and saturated timing belt - both need to be replaced.. the amazing news - VW is going to pick up the tab - under the drivetrain warranty! I had the timing belt done at 40K (when it was initially recommended) and was going to wait until 100K this time.. So other than 1 night of hotel (and four days of a rental car!) - they got the wrong parts in or something - it didn't turn out too bad. I'll pick it up today or tomorrow.
Any other instances of TDI waterpumps failing? And abruptly? In my 92 Jetta (gas) the waterpump would make rumbling noises before failure and started to leak slowly.. Perhaps it's hard to hear under the rumble of the TDI engine..
Nathan Dennison
Indianola, IA
1999 TDI New Beetle
Nathan Dennison
Indianola, IA
1999 TDI New Beetle
