dougsbug
Thank you to Frank06 and R90sKirk and all the others that looked at and offered advice on my PD cam.
If anyone else would be willing to offer an opinion here are the most revealing photos I could take.
Look carefully at the top, right area of the cam lobe.
In this one you may see the cam follower with some marks.
I don't know if this is bad, really bad or something that will go for another 100,000 miles. This is the worst one. I think it is no.3 exhaust?
The car is an '06 Jetta with now, 104,500 on it. It is new to me and I have no way knowing what oil was used.
My options as I see it are to try Frank06's cam bearing and oiling modification or replace the entire cam, followers, bearings, etc.
The previous owner had their mechanic replace the timing belt and water pump- but not the tensioner or rollers. So I need to have that done.
What are my other options? What would you do?
What oil would you use? Please be specific -brand and wt.
Thank you all.
Thank you all.
