cevans
TDIClub Enthusiast, TDI Parts Ninja Vendor , w/Bus
Currently new actuators for the A5 Jetta BRM are not available. Borg-Warner, for whatever reason, made the actuator "non-replaceable", riveted it onto the turbo and doesn't provide replacements.
However, VW does offer a replacement actuator for the new, 2.0L common rail engines. The common rail motor also uses a BW turbocharger, and the two actuators are remarkably similar. Identical in physical size, both react to vacuum in the same way.
The bad: The brackets are different and it is unclear if the feedback loop is compatible.
The common-rail actuators are part number 03L198716A (available for around $250 from a local dealer or your favorite TDI vendor). I would do this experiment on a friend's car but we just put a PD140 turbocharger in it.
Any takers?
Some photos - Side By Side
Common Rail Actuator Alone
Any takers?
