Wow! I left my car at Ganley Volkswagen for 2 days, and after spending $430.00, they couldn't fix it, and the car is still throwing the same codes!
Can you solve this difficult puzzle?
Here are the codes :
000257 Mass Air Flow Sensor (G70)
Impausible Signal
001026 EGR System
Excessive Flow
005686 Power Train Data Bus
Missing Message from Airbag Controller, Value of resistance too great
Do the MAF, the EGR share the same ground?
This has become a whack-a-mole project, and I seem to be the mole getting the whacking!
The VW is a Jetta Wolfsburg Diesel 1.9 2006-2007 model, with 180,000 miles on it.
Previously I have ultrasonically cleaned the Altitude Sensor (boost sensor) and cleaned the N75 valve, and ultrasonically cleaned the EGR valve (it was pretty dirty and sticky with black gunk, but it is now nice and clean.) I replaced the MAF with a new Chinesium made MAF.
I replaced the Anti-Shutter valve after it threw a code.
Previously the MAF problem was different. Previously as soon as I turned on the car the MAF immediately threw a code, reporting signal too low.
Now the MAF does not throw a code immediately upon starting the car. Now the MAF throws a code after the car has been running for about 15-30 minutes, after the engine has got to operating temperature. It seems to throw the code at freeway speeds, as I remove my foot from the gas pedal slightly to deaccelerate, throwing the code as I do so. And I guess it also throws the EGR code at the same time. At least both codes show up at the same time when I scan the system.
About the airbag problem, it's likely not related. I am going to try some Stabilant 22 on the airbag controller ground bolts, to see if that fixes the problem.
Thanks for any ideas you have. I need to drive from Cleveland to Newark in a couple of weeks and I want my check engine problem fixed by then.
Impausible Signal
001026 EGR System
Excessive Flow
