Old April 23rd, 2012, 11:57   #16
tdiatlast
Originally Posted by APT View Post
tdiatlast, 0.0013 dollars per mile. Or, 2,000 cents divided by 15,000 miles if you choose.
The 40k mile DSG service costs more, like 1c/mile.
...too early in the morning... You're right, I'm wrong!
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old April 23rd, 2012, 17:27   #17
Rico567
Originally Posted by TheGrove View Post
It's in the right rear quarter below the trunk floor. You access the tank thru the trunk and a door on the floor in the little "cubby" between the rear tire and the back of the car.
This keeps the center of gravity low, and also explains the design of the bottle/nozzle used for filling. As is obvious from previous comments, checking the tank level can't be done visually, and this "VCDS" software is obviously a PITA to use for anything simple like this. Therefore, a bottle design that allows a fill but will cut off when removed to prevent overflow / spillage.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old April 23rd, 2012, 17:27   #18
TomB
Fuel Economy: 34 mpg on first tank
Originally Posted by wolfsburg_de View Post
FYI, with VCDS, I believe you can find the level (expressed as a percentage) in Engine -> Advanced Measuring Values -> 98-0:Sensor for reducing agent fill level. My Passat with about 3600 miles, mostly around town, shows a fill level of 77.03 %.
I just checked mine 2999 miles on the car, 99.85% for the value 524 and 100.02 for value 605. I did not find a 98-0 value on the advanced measuring values under engine.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old April 23rd, 2012, 17:49   #19
Sbieshelt
TDI(s): Jetta passat
I went in for my 10k checkup and had to argue with the service dept. they didn't even know the Passat took ad blue. I hate dealers that know less about the car than the customer.
Be careful if you go to Waldorf vw
Sbieshelt is offline   Reply With Quote
Old April 23rd, 2012, 18:21   #20
tdiclubfan
I hope you didn't buy your car from this dealer.
tdiclubfan is offline   Reply With Quote
Old April 23rd, 2012, 20:52   #21
TomB
Wolfsburg,
What values should I monitor to make sure the UREA injection is actually working. I can't believe I have used that little AdBlue in 2000 miles.
Old April 24th, 2012, 03:49   #22
vwtom
Default dweisel
Originally Posted by dweisel View Post
Does this fit perfectly on your Benz?
vwtom is offline   Reply With Quote
Old April 24th, 2012, 03:52   #23
TheGrove
I would agree, so I don't worry about it. If it gets low a warning comes on with about 1,000 miles left to go so you have time to get some AdBlue and put it into the tank. Remember if you are still in the 36,000 mile free service then you just need to stop by the dealer and have them add some.
Yep, I believe when I had my 1st service done at 10K the dealer didn't realize this either and didn't fill it up because at 15K miles the warning came on. I took it back and had them add some. I also made sure at the 20K service to specifically make sure they filled the tank so I haven't had the warning come on since and I'm within 2K of the 30K service.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old April 24th, 2012, 13:10   #24
verylongdrive
TDI(s): Golf,2001
Fuel Economy: 43/46/50
While that's probably a perfectly fine place for a non-essential fluid container, the legal requirement to STOP NOW if the tank is empty because no DEF means you might pollute in a day as much as a big truck in 5 seconds will statistically cause quite a few rear-ended TDIs with relatively minor damage to become instantly undrivable. Not good.
verylongdrive is offline   Reply With Quote
Old April 24th, 2012, 13:43   #25
kydsid
TDI(s): 2012 Passat
I doubt VW would manufacture a DEF tank that fragile it just doesn't make any sense given it is located near the fuel tank. If it was that fragile then shards could pierce the fuel tank. And if it wasn't any less fragile than the fuel tank, a crash that would damage it would damage the fuel tank also. In either case you don't have fuel let alone DEF.
kydsid is offline   Reply With Quote
Old April 24th, 2012, 14:42   #26
IXLR8
From what I have read, if tank goes empty it does not 'STOP NOW', but you can't restart after you shut it off.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old April 24th, 2012, 20:26   #27
tdiclubfan
Is there any difference between different brands of AdBlue or just pick whatever is the cheapest and easiest to get?
Old April 24th, 2012, 20:32   #28
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Get whatever makes your wallet happy - it's all the same.
It is referred to as AdBlue or Diesel Exhaust Fluid (DEF) and is available at most auto parts stores and truck stops.
Trusted TDI Mechanics Map || TDIClub Chat
Old April 24th, 2012, 21:31   #29
compu_85
Gadget Guy
compu_85's Avatar
According to my manual you get 20 startups after you run out of fluid. If you manage to ignore the yellow light, then the red light for that long you probably shouldn't be driving.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old May 9th, 2012, 16:28   #30
dachman1
Fuel Economy: 35/46
Originally Posted by Ozzmosis86 View Post
I asked for an empty jug at my 10k mile service. They gave me a 2.5gal jug, but it didn't have a special neck or anything on it, I ended up just throwing it away. I am not sure how to get one of the correct jugs, maybe my dealership has the tool you can buy and they are using different jugs.
If anyone has gotten the correct jug, please share a picture.
I got my 10K done on Monday. They gave me the empty bottle with the special top. The guy indicated that the nozzle part breaks tabs if unscrewed making it basically a one time use bottle. I am pleased to report that he was wrong and I was able to unscrew the top, add fluid to the bottle and use it. So, in my case, it's a reusable bottle. Buy DEF at Autozone for about $5 when the warranty/service runs out and use the specialized bottle to fill. If the nozzle part wears out or breaks, I'll just buy one more bottle of it and keep refilling it.
dachman1 is offline   Reply With Quote
Adblue? cj42 VW Passat Family (NMS and B7) TDIs (2012+) 78 December 9th, 2015 12:37
AdBlue whizznbyu Audi SUVs (Q7 & Q5) 74 November 1st, 2015 13:34
adblue ?? Lm2lg TDI 101 10 January 14th, 2012 12:21
adblue ?? Lm2lg VW Touareg TDIs 3 January 13th, 2012 13:09
AdBlue Sources Drivbiwire VW Touareg TDIs 11 July 25th, 2009 15:06
Page generated in 0.16734 seconds with 11 queries
[Output: 135.44 Kb. compressed to 114.40 Kb. by saving 21.04 Kb. (15.53%)]
