Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old June 3rd, 2011, 11:28   #166
ctnatureboy
ctnatureboy's Avatar
http://www.nytimes.com/2009/09/13/au...13MILEAGE.html
ctnatureboy is offline   Reply With Quote
Old December 19th, 2012, 19:29   #167
timmyc4
timmyc4's Avatar
TDI(s): 2013 Passat
Fuel Economy: 51.3 Best @ 65mph/300mi trip
Thumbs up LRR - Best Advise
Don't waste your time.
I get rid of my 160lb Girl Friend, and noticed a 1.2mpg increase this last year.
However, last yr's winter was mild, and she was great in pushing me out of drifts, so I'm considering reconcilliation at this point, and she was good for the ride,though she has lost 30lbs.
timmyc4 is offline   Reply With Quote
Old December 20th, 2012, 05:46   #168
powerfool
Fuel Economy: 50 mpg
Replacing my faulty turbo actuator and getting Michelin Defender XT tires is the difference between me getting 41 mpg and 45 mpg consistently. Adding in some hypermiling got me to 51 mpg on a tank doing just my in-town commute. I would like to see what I can get on a long-trip, now.
I had mine installed at Sam's Club, where they were (and are, again) offering an instant savings about $70-80. They usually run this and a Goodyear offer.... you can usually get one, of not either, of these all of the time.
powerfool is offline   Reply With Quote
Old July 30th, 2015, 13:44   #169
gilberjj
gilberjj's Avatar
TDI(s): 2006
I rode in a tdi with Michelin Hydroedge tires and they sounded like big lug mud tires. The road noise!!!! Holy crap!!!! I won't be buying those.
06 jetta tdi dsg BRRRRRRMMMMMM
gilberjj is offline   Reply With Quote
Old July 30th, 2015, 13:49   #170
I don't think you will, because I don't think they've made them for some time. They were replaced, more or less, by Defenders.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old July 31st, 2015, 17:17   #171
F6Hawk
Talk about bringing a thread back from the dead!! It started back when 90K tires were shipped for $55 each, and ended 2.5 years ago. Until yesterday, that is...
F6Hawk is offline   Reply With Quote
Old July 18th, 2016, 19:20   #172
dubStrom
dubStrom's Avatar
A slight drop in rpm at cruising speed is good for some additional mileage, as long as the tire isn't lots heavier.
I have stock 16" wheels on my 2014 JSW. I am considering a ~0.7" diameter increase, and 2 pound per tire increase in weight from OEM with the following Conti:
PURECONTACT WITH ECOPLUS
205/60R16 91H
91 is the lower weight limit (~1300 pounds instead of ~1500)
The H rating is 130 mpg, not 150mph. Same rating as OEM tire:
Stock tire is a 205/55R16 91H ContiPro Contact
It will drop the revolutions per mile from 837 to 808
That's just a 3.5% drop in rpm at ANY speed. There's certainly enough torque to handle this under most situations.. It is a subtle change.
Any thoughts?? I've done this before (Passat) with a modest gain in FE, but that was a slightly stronger engine (2013 NMS TDI).
ONE other thing... wear rating of the Pro is 400, and for the EcoPlus Pure Conact it's 700. Traction is rated identical.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Page generated in 0.12482 seconds with 10 queries
[Output: 79.38 Kb. compressed to 68.87 Kb. by saving 10.50 Kb. (13.23%)]
