Old April 23rd, 2018, 17:42   #1
N519AT
N519AT's Avatar
Default Injection Pump Position During TB Change
So I've managed to get my hands on another TDI...this time a 2003 Wagon. It's in great condition.. totally unmolested, no mods, 195k, all MX records all the way back to when it was first purchased. I'm pretty proud of this find, but I did buy it with the timing belt a little overdue to be changed.
So I get it home, park it in the garage and start the surgery, following the tutorial from this site to a T. After putting the new timing belt on and rotating the engine through by hand 4 revolutions I went to put the IP lock back in to check the continuity of the timing. I put the engine at the TDC mark as indicated on the flywheel and it was very difficult to get the IP lock back in. I had to wiggle the crankshaft bolt in order to get the lock pin in place, but I did get it in at the 1 o'clock position. Doing a little bit of investigating, in order to get the IP lock to go into the hole on the pump freely and slide in & out with no effort, the flywheel has to be in this position: https://imgur.com/lup8OEs
Now I can get the lock in when it's much closer to TDC on the flywheel but it's more of a force than easily slipping in. When I put the IP lock pin in place before removing the belt, I noticed the same thing but figured it would somehow go away with the new belt and hardware.
Is this a problem? Or am I still within spec on this since the pin will go in at TDC (although it not easily).
1999.5 Volkswagen Jetta TDI GL, 5 Spd Manual, 155k
"Mods"
20G Phatbox
5 Brake Light Mod
Ventectomy
Pipe Insulation (Seasonal)
Hamman Mod (With on/off switch)
Defender Tech Skidplate
Fuel Sender Mod
N519AT is offline   Reply With Quote
Old April 23rd, 2018, 18:16   #2
hollowhead
hollowhead's Avatar
Fuel Economy: 40ish beetles, 52 wagon
Did you loosen the bolts on the IP pulley? Unless I missed it I didn't see anything about cam timing.
hollowhead is offline   Reply With Quote
Old April 23rd, 2018, 18:25   #3
N519AT
N519AT's Avatar
Yes, the bolts on the IP pulley were loosened. I did center the pin in the oval hole on the IP sprocket before putting the belt back on.
Cam was locked at TDC with the Metalnerd locking tool (pass side lobes facing up).
"Mods"
20G Phatbox
5 Brake Light Mod
Ventectomy
Fuel Sender Mod
Old April 23rd, 2018, 18:30   #4
hollowhead
hollowhead's Avatar
How is the cam timing now with the crankshaft at tdc?
Old April 23rd, 2018, 18:56   #5
flee
Fuel Economy: 40-ish
At TDC and with the cam lock in place loosen the IP bolts and adjust the pump
shaft using a 22mm (I think) socket until the pin fits as it should.
The bolts should be near the center of the adjustment slots. If they aren't, the
pump sprocket may be a tooth off.
2002 Jetta GLS TDI wagon
Last edited by flee; April 23rd, 2018 at 19:06. Reason: changed socket size to 22mm
flee is offline   Reply With Quote
Old April 23rd, 2018, 19:49   #6
jokila
jokila's Avatar
Fuel Economy: 52/45/40
That is the most important relationship to be certain to have correct.
The IP can be close enough to be really tight to get the pin in. With the 3 bolts on the IP you can adjust for final starting.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old April 23rd, 2018, 20:29   #7
N519AT
N519AT's Avatar
Thanks. Did what you said and got it to the point where it slides in with no effort. I feel pretty stupid now that the fix was so simple.
"Mods"
20G Phatbox
5 Brake Light Mod
Ventectomy
Fuel Sender Mod
Old April 23rd, 2018, 20:40   #8
Genesis
Fuel Economy: 53/48/42
Yep.
I assume you STILL have a locked cam without stress on the plate (you can remove and re-insert it) with the TDC mark centered? You want that bang-on.
Genesis is offline   Reply With Quote
Old April 23rd, 2018, 21:00   #9
N519AT
N519AT's Avatar
Yes, after rotataing the engine through again both the cam lock and the IP lock pin are able to move in and out freely at TDC.
"Mods"
20G Phatbox
5 Brake Light Mod
Ventectomy
Fuel Sender Mod
Old April 24th, 2018, 10:10   #10
Nevada_TDI
As long as the mark on the flywheel is at the right spot, the camshaft is locked in the correct position, and the IP pin is in the right spot, all should be well.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old April 24th, 2018, 12:14   #11
flee
Now have you checked the timing in VCDS? Then you can adjust it where you want it.
I had to reposition the IP pulley on the last TB change after getting everything
set - the bolts were all the way to one side of the slots. So you did better than I!
Old April 24th, 2018, 13:34   #12
Nevada_TDI
Yesterday I swapped a new IP into my ALH; after I set the TDC on the flywheel and verified the camshaft was oriented correctly, I put the pin into the IP, locked it down and re-set the tensioner on timing belt. Here is what is odd: according to VCDS my IP timing was at 138 degrees. This is not the first time I have installed a pump and had the same reading in VCDS Timing Graph, everything seemed to be okay and she runs fine now. Any ideas?
_______________
Old April 24th, 2018, 14:10   #13
N519AT
N519AT's Avatar
On the to do list...the car isn't running just yet. Waiting on some parts and I kind of treat this as a something to do while I'm on call. I will probably hold the record for the longest time to do a timing belt.
"Mods"
20G Phatbox
5 Brake Light Mod
Ventectomy
Fuel Sender Mod
TB Change No Start and VCDS Code P3008 19464 - Camshaft Position Sensor (G40) armyschus VW MKIV-A4 TDIs (VE and PD) 2 July 15th, 2017 18:18
Tensioner position after TB change OAG TDI 101 8 December 22nd, 2009 18:28
Injection Timing Issue - TB Change bbarbulo VW MKIV-A4 TDIs (VE and PD) 23 March 10th, 2007 09:57
Injection Pump Lock Pin Position: Does it matter? TDI Nut VW MKIV-A4 TDIs (VE and PD) 15 February 13th, 2006 23:06
Change Water Pump @ 60,000 TB Change??? BAMA TDI VW MKIV-A4 TDIs (VE and PD) 2 June 18th, 2002 08:19
Page generated in 0.16002 seconds with 11 queries
[Output: 121.34 Kb. compressed to 102.22 Kb. by saving 19.12 Kb. (15.76%)]
