Old April 20th, 2018, 06:45   #1
GOTSMOK
Default 03' Jetta idles rough?
hey guys, I have recently brought my jetty back to life after a broken timing belt a couple years ago. I bought another whole car to just swap the engines out since that was easier and cheaper route for me than fixing the one I had. but long story short, I spent a weekend getting it all swapped over and finally got her cranked up and running and it idles pretty rough but revs up fine, no check engine light and only codes are brake like switch and boost control solenoid. I thought maybe it was a fuel supply issue but if that was the case it would idle fine and not fuel anymore. im at a lost here. I've drained the tank, cleaned the sending unit, new fuel filter, conditioned the fuel.... any help would be appreciated! Thanks, Mike.
GOTSMOK is offline   Reply With Quote
Old April 20th, 2018, 07:10   #2
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Connect VCDS and report back the injection quantity. The pump may be overfueling at idle.
For more information check out this article.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old April 20th, 2018, 08:23   #3
GOTSMOK
I do have a 30 sec video with my solus hooked up would that tell you anything if i posted it? and figure out how lol.
Old April 20th, 2018, 09:21   #4
jokila
jokila's Avatar
I don't know what you mean. If you don't have vcds or some tool to give you the injection quantity then you won't be able to check out the recommendation I sent you.
If you need access to VCDS, there are people probably in your area with the tool. http://www.maptive.com/ver3/VCDS_Locator
Old April 20th, 2018, 09:24   #5
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Post video at pics.tdiclub.com, detailed instruction below. Basically you have to log in again, upload and check that your file type is listed. Then harvest a linky to put back here.
Don't know from solus. We're wanting to see Group 000 Field 4, better yet Group 001.
A4 TDI engine measuring blocks/groups
Old April 20th, 2018, 09:31   #6
GOTSMOK
ok gotcha, so on the solus (snap-on tool) scanner it will show injection amount, start of delivery, DC start of delivery valve and slide sensor. im thinking I might need to adjust the cover like you were saying. thanks guys for the replies as well!
Old April 20th, 2018, 19:36   #7
KyleMillione
Fuel Economy: 02 (auto) 39, 03 (man) 48
How long was the pump your using left open? I just ran into an issue with a know good pump from a year ago was installed, and it was no good. It could be gummed up from sitting so I’m gonna run some diesel purge into it and let it sit to see if something in the top part is stuck.
2002 Green Jetta Auto 220k RIP
2002 Black Jetta Auto 240k
2003 Silver Jetta 5sp 290k
KyleMillione is offline   Reply With Quote
Old April 24th, 2018, 13:01   #8
GOTSMOK
I capped everything off when I took the engine out of the other car, but I ended up just tapping the top cover towards front of engine and it runs perfect now. thanks to the other guys for the info and replies! now if only I can figure out why these D@#$ brake lights wont work and glowplug light is flashing. I have installed a new brake light switch and bulbs are good.
Idles rough after emission fix pebjr VW MKV-A5 Golf/Jettas 4 February 13th, 2018 20:26
Cam replacement and now Idles rough and smokes Curmudgeon VW MKV-A5 Golf/Jettas 23 May 1st, 2014 07:18
Mk4 idles rough when slowing down 98 jetta TDI 101 9 January 10th, 2013 06:45
Runs rough, idles high?? brp TDI 101 2 October 3rd, 2008 15:36
Cold starts ok, idles rough, then dies? Gothmolly TDI 101 8 February 5th, 2007 16:58
Page generated in 0.14217 seconds with 11 queries
[Output: 85.29 Kb. compressed to 73.59 Kb. by saving 11.70 Kb. (13.72%)]
