Old April 19th, 2018, 16:38   #1
tdidieselbobny
tdidieselbobny's Avatar
Default Injection pump leak from bolt on body of pump...
Hi folks! I noticed my IP is leaking from a bolt head on body that faces the glow plugs. What is this bolt? Does it have a seal? Will I screw anything up or springs fly out if I remove it? It's a bolt head on back side of pump body, just beneath the the top part of the pump, close to where the hard lines come into the pump. My searching hasn't come up with anything yet, I'm hoping someone could post a pic and tell me what it is for.... this is on the '03 ALH pump....
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 30k miles....'16 Kubota BX1870 MMM/FEL, 178hrs!And now an '03 Jetta TDI 5spd w/ 427k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old April 19th, 2018, 16:49   #2
burn_your_money
If it's has a 13mm head on it's just a copper/aluminum sealing washer behind it. Just snug it up a bit and carry on. It's possible that the seal has corroded away and will need to be replaced. Nothing but fuel will come out if you remove it.
burn_your_money is offline   Reply With Quote
Old April 19th, 2018, 17:00   #3
tdidieselbobny
Where can you get this seal? The pump has 419k miles on it.... it looks like 13mm head, forgot to check and see what size it was.
Old April 19th, 2018, 21:21   #4
KLXD
Autozone and the other have a small box-o-washer assortment that might have the right size.
I'll bet that snugging it as suggested above will fix it.
If you do pull it the pump body will drain about half way. Might take some cranking to get it to go unless you have a vac. Spend as little time as possible with it out and maybe the lift pump will stay primed.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old April 20th, 2018, 02:49   #5
jimbote
jimbote's Avatar
it's a pressure test port plug, just snug it up and it'll be fine ... no need for a new sealing washer
Old April 20th, 2018, 12:54   #6
tdidieselbobny
Cool, thanks. I'll try snugging it up first and taking for a drive- need to make sure the new oil cooler o-ring I put in stays not leaking...
Old April 20th, 2018, 17:56   #7
tdidieselbobny
Eh,my luck, still leaks after a little snugging up. At least the oil cooler orings aren't leaking....
Old April 20th, 2018, 21:05   #8
KLXD
You sure it's the plug and not running down from the QA/body joint or the top cover?
Old April 21st, 2018, 08:26   #9
ghohouston
ghohouston's Avatar
Fuel Economy: 40 Mpg
I had that 13mm plug loosen up on mine. Try snugging it up like they said.
2001 Silver Jetta Sedan TDI 5 Speed,3" Kerma turbo back straight pipe
Allard EGR Delete
Bosio DLC 764's. 1997 Ford F350 CCLB 7.3 Powerstroke Diesel ZF5, straight piped
ghohouston is offline   Reply With Quote
Old April 23rd, 2018, 18:56   #10
tdidieselbobny
I'll have to double check. I'll have to get someone to run throttle at higher RPM's to see if I see anything spraying out anywhere. I now have wet injector return lines(the cloth braided), fuel filter has fuel collecting on it(was a known problem when I bought car), and the lines that are near firewall that come up from tank that have the disconnect, the rubber hose that goes to filter seems to be damp on the outside. Not sure if the PO ran biodiesel or not, I'll have to ask. I'll have to get some of that injector return line, I bought some 1/8" fuel line but not sure if that'll work or not. I did get some copper washers, so I'll dry the area up the best I can and see if I can see where fuel is coming from....
Injection pump triangular bolt apbiii VW MKIV-A4 TDIs (VE and PD) 13 November 16th, 2017 10:24
Oil leak. Coolant leak. Injection pump leak. Chris_TDI_98 VW MKIII-A3/B4 TDIs 3 April 23rd, 2016 12:00
injection pump bolt vince557 VW MKIII-A3/B4 TDIs 5 May 17th, 2012 00:45
Injection Pump bolt Missing barnaby VW MKIII-A3/B4 TDIs 2 November 10th, 2010 05:46
Help! Broken Injection Pump Bolt TonganDiesel TDI 101 10 July 31st, 2006 19:44
Page generated in 0.14800 seconds with 11 queries
[Output: 102.39 Kb. compressed to 87.34 Kb. by saving 15.05 Kb. (14.70%)]
