Old April 12th, 2018, 08:22   #16
Schoust
I have to laugh! My experience on my sons 99.5 was exactly as Oilhammer has described. I was a PITA. Then I struggled getting the new in because of scoring of the metal when I removed the old. Does anyone know of a cheap tool or perhaps an easy way to make my own so it will be easy to get the new in?
I would prefer that route.
Schoust is offline   Reply With Quote
Old April 12th, 2018, 09:55   #17
KrashDH
TDI(s): 2002 Golf
Are you putting in OEM or the Cupra R bushings?
KrashDH is offline   Reply With Quote
Old April 12th, 2018, 11:28   #18
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Will the A3 bushing tool work on the MkIV? They look alike from the pics.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old April 12th, 2018, 17:08   #19
UhOh
UhOh's Avatar
Lots already documented on this. All-thread rod, nuts, washers and some wood. And then likely, especially with Cupra R bushings you'll need a cup on the receiving side: I have and use a front wheel bearing outer race. The installation tool, however, isn't all that much if I recollect correctly (but, you'd still need a deep cup of some sorts if you do Cupra R bushings).
Old April 12th, 2018, 19:21   #20
Seatman
Seatman's Avatar
Fuel Economy: No idea
Originally Posted by oilhammer View Post
That has never been my experience. I always have had to cut/air hammer/chisel/saw metal outer sleeves apart. Remember, YOUR car was assembled at a different plant than ours. It may be yours had a different bushing supplier, or only the wagons sold here (which were made in Germany) used something different. Depending on how badly rusted in place they are, I can spend anywhere from 30 minutes to an hour per side with them. Pushing the new ones in is easy (with the tool). But getting the old ones out....
All the ones I've done have been plastic casing from 99 to 2005, I've never come across a metal casing in a mk4 yet that's standard.
That is a strange alteration to make just for a different market, I bet they're cheaper or some crap like that.
Seatman is offline   Reply With Quote
Old April 13th, 2018, 04:59   #21
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Ha, you've never experienced a Westmoreland Rabbit, have you?
oilhammer
www.cardocautomotive.com
Old April 14th, 2018, 15:10   #22
Schoust
Well the moral of this story is before assuming your issue is what you think it may be inspect it thoroughly. Unfortunately I was super busy last week and the place I buy most of my auto parts from is far away from my home. That being the case I purchased the new bushing and borrowed the real deal tool from a buddy who had it. I jacked the car up and inspected the bushing and it was perfect? What gives here lol? I looked it over and used a long bar to load it up and could not duplicate the noise so I removed the lower shock bolt to get a better look and From what I could tell the spring appeared to have turned in the purch? Is this possible? I have never changed anything back there except the pads. How could the spring rotate? Anyway I turned the spring to where it seemed to sit properly and the noise is gone. Quite confused as to how this could have happened but pleasantly surprised that I didn't have to do this PITA job.
Thanks for the advice!
Old April 16th, 2018, 11:29   #23
Nevada_TDI
It is well documented if the springs are not sitting "perfect" on the seats they will make noise. As far as the springs rotating on their own, that is a good question. Did you happen to hit a pot-hole recently or come off the edge of a curb? I do wonder what shape the shock(s) are in... is the upper bearing 100% solid, and is the shock smooth in all it's travel?
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old April 16th, 2018, 15:27   #24
OlyTDI
TDI(s): '04 Golf
Can you elaborate on the "cup" needed for the Cupra R bushings? Does the bushing need to seat past the end of the receiving piece? If so, what does this cup seat against when squeezing the bushing in?
Thanks!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old April 16th, 2018, 19:23   #25
Seatman
Seatman's Avatar
Thanks!
The proper tool is cupped, the end of the bush sticks out past the hole anyway but sometimes a poly bush can require that little extra push to get it fully home.
I've just replaced mine with poly though and the proper tool worked perfect.
Old April 16th, 2018, 19:25   #26
Seatman
Seatman's Avatar
A what now?
I've done a mk3 rear beam bushes with a rottweiller sitting on my head, does that count for anything?
Helping a friend with the car on the deck and his bloody great dog came over and sat on my head lol
Old April 16th, 2018, 20:35   #27
Genesis
Fuel Economy: 53/48/42
Front end or back end of said dog? :-)
Genesis is offline   Reply With Quote
Old April 16th, 2018, 20:47   #28
UhOh
UhOh's Avatar
Clearly folks don't know how to proceed in such operations! No one has mentioned being sure to have a dogbone on hand!
Old April 19th, 2018, 18:38   #29
Victor Huge
Victor Huge's Avatar
TDI(s): Mk7 Golf TDI
No one did urethane bushings? They're so easy to install!
Victor Huge is offline   Reply With Quote
Old April 19th, 2018, 19:30   #30
Seatman
Seatman's Avatar
The smelly end!
It's not the install they have trouble with, it's removing the old ones. Over here in the UK all the ones I've dealt with have had a plastic sheath you just break to get them out but they're on about a metal sheath.
I'm sure it's nothing the correct size hammer couldn't sort though lol
Rear Axle Beam Bushings augie dog VW MKIII-A3/B4 TDIs 34 October 16th, 2015 22:56
Rear Axle beam bushings.. Which ones? G Men 08 VW MKIV-A4 TDIs (VE and PD) 7 October 27th, 2014 18:35
Rear axle beam bushings SkyRyder55 VW MKIII-A3/B4 TDIs 20 June 23rd, 2014 22:58
which rear axle beam bushings to go with? bikerboyriley Upgrades (non TDI Engine related) 3 July 16th, 2012 18:10
Rear axle beam bushings, Need help Rob02f350 TDI 101 15 April 3rd, 2011 16:53
Page generated in 0.15341 seconds with 11 queries
[Output: 131.78 Kb. compressed to 110.50 Kb. by saving 21.28 Kb. (16.15%)]
