frambach
I'm looking to use the VW ECM to tell my Toyota cluster some of its information.
- I'd like to hook the 4wd light in the Toyota cluster to the glow plug indicator (our truck is a 2wd). Anyone know which pin out of the ECM I can tap into? Looks like ECM pins 6, 7, 16, 20, & 27 go to the cluster.
- I'd like to have the ECM drive my oil pressure gauge or at least my oil pressure dummy light
- I'd like to use the ECM's data to drive the stock Toyota 3VZ tachometer (I've read all kinds of stuff about this: data acquired from pin 27 (Jimbote), pin 110 (possibly e*clipse), replace 15ohm resistor in tach/cluster w/ 33ohm (e*clipse & dustystdi). Looking to clear the air on this topic.
- have the ECM have the ability to light up the Toy's CEL (possibly pin 24)
Additional info: 1992 Toyota Xcab pickup DLX, 2002 ALH 121 pin ECU.
