Newgene
Not on a TDI model, but I don't see why this is not applicable to the MkV TDI's. I am currently trying to narrow down what I think may be a failed compressor. I still have the wife's 2007 2.5L Jetta that started blowing hot air last summer. I have gauges on it now, and it has been sporadic while trying to figure out what's wrong. Here's what I know:
- Driver's side fan runs when up to temperature. This is on low speed.
- Driver's side fan ramps up when you move click the AC switch. It seems to kick on every time when I move the selector to defrost.
- Passenger side fan does not turn at any temperature or AC setting.
- It is around 95F outside, and both gauges normalize to ~125 psi with the compressor off.
- Now, with the AC switch on, the low side fluctuates 115-120 psi, with the high side running around 130 psi.
- Earlier today, with the system running, the low side was running around 75 psi, and fluctuating, while the high side was around 150 psi.
- I added maybe an ounce of refrigerant (enough to turn a half-used small can cold on the outside, but no big change in weight), and the vents actually blew cold for about 15 minutes.
- The car has been sitting outside where rats have been in out of the engine compartment. It's an extra vehicle that we have periodically used as a spare. Although maybe not likely, it is possible a rat has chewed something.
- I looked in the under hood fuse panel, and none of the fuses appear burnt. I tested continuity on all the smaller fuses, and the two big green 30A fuses are good. The cables going up the side of the box are not discolored and look fine.
