r1d2h3
My tranny has a pulsating slip at crusing speed.does not slip at a hard pull or hard acceleration any suggestions.thanks.
The year fits with an 01M. The behavior fits an auto. A slipping manual would be worse on acceleration, not better.Are we sure r1d2h3's got an 01M? He didn't specify in the first post.
what you are saying is correct.Please explain what you mean by pulsating slip. If you mean the tendency to increase in rpms a couple of hundred then back down, then it is a common wear indication in the valve body of the transaxle.
Look up CoolAirVW's threads on the 01M transaxle. It will be good info and guide you on trouble shooting.
Cheers,
PH
thanks for the link,thats good info,thanks for your help.Here is the original tutorial:
http://forums.tdiclub.com/showthread.php?t=62154
Mind you, DO NOT do 30 clicks in. Long story short, it turns the pressure up too much and grenades the transmission. Doing 5-7 clicks raises the pressure a little, and can prolong the life of the transmission for a little while. However, your milage may vary.
