zehair
Hello Folks,
I have been on this forum for a while and this is my first participation I will share with you my car project since 2014. Its a Golf MK2 from 1983 GTD - AKA Blue Machine.
This car means a lot to me for its history.
I start the story quickly, when I was still 7 years old, I was very fascinated by the golf MK2 of my French teacher, I remember it was all gray with the acronym GTD on the back. It was the first time I fell in love!
18 years later, I decided to look for the same car from my teacher to buy it. A long history of researching and in the end to my surprise I unfortunately found it in a miserable state abandoned in a field. Its last owner was a Soldier.
I was upset and shocked by her condition, but I made the decision to save her anyway. It’s the dream no matter how much it will cost. I bought it like that and took it home. I leave you with some photos from the 2014 archive :
Please click here to see all photos 2014
After a year of hard work, it sees its first day in early 2015, I equipped it with an AHU engine with a mechanical pump of AAZ and turbo K14, and like all unmodified TDI-m it went out 62hp and 100nm. Then I decided to push the engine to get more power : 125hp and 220nm with these modifications:
- Turbo K14 at 1.3bar
- Exhaust 50mm
- modified pump with 10mm head, DE110 camplate, Iveco Gas lever and LDA.
- Gearbox CHD from AAZ engine
Here are some pics of what I did at that time :
Please Click here to see all photos 2015
In 2017, I still wanted power and I made even more modifications:
- Turbo HE211w at 30psi (Thanks to AlCaid)
- Fmic 2’’ piping
- Exhaust 60mm (57mm from inside)
- ASD Gearbox From 1Z engine
- XTD stage 3 clutch
- Home made pump 11mm
- 0.280mm
With this setup it marked 220hp and 380nm on a dyno... I leave you with photos of the archive and drags :
Click here to see the vidéo (acceleration, drags...)
And here to see all photos 2017
For this year 2020 I intend to push the beast again towards 300hp ++.
Here are the modifications that I am making:
- Pump by Dieselmeken for 300bHP
- Pump lift 0.6bar 250liter / h (from PD engine)
- 0.370mm injector nozles
- 6speed gearbox
- Sachs SRE pressure plate and organic disc 240mm
- intercooler water / air + 2.5 '' piping
- Exhaust 3''s
-Water/Methanol Injection only 250cc/min
For the turbo I bought a new S200g (69mm / 58mm turbine and 53.25mm / 76.3mm compressor) but after a discussion with JukkaTDI from TDI Finland Club, its seems like this turbo is over-sized for a 1.9tdi-m , especially with A/R 0.85.
Then I found another, but used, turbo from Mercedess Atego OM904LA (170bhp / 700nm). And I ordered a new CHRA.
Here is some pics:
Please click here to see all photos 2020
Hope you like this project. If yes, stay tuned !
- Exhaust 50mm
- Fmic 2’’ piping
- 0.280mm
- 6speed gearbox
- Exhaust 3''s
HTML:
Turbo specs:
* Compressor: 44mm / 63.5mm
* Turbine: 55mm / 46.2mm
* Turbine housing: 5.82 cm-square
