Trakpak
Well I played around with it today. I did the scan and save first.then I lengthened the glow plug time from some info I found on here. Then I checked the injection pump timing. It was in spec but on the low end. It took 4-5 times moving the bolt but I got it right on the blue line on the graph. Then I checked the iq and it was 2.8-3 so I moved it up to 4 to lean it out a bit. I saw conflicting info on weather or not it will increase mpg but I figured I’d try it since I’m only getting 40.
Any recommendations on things I should check or change? This car is a mpg car for me. Is there any settings I should change to help that?I have other cars that scoot when I want them to haha.
But knowing me I’ll be looking into a tune soon. I can’t leave anything alone. Everything can always be better!
