Bill1975
2011 A3 - 89,000 miles. This is my first TDI so pardon my ignorance if I'm missing a few things.
Tonight the CEL came on, and glow plug light started flashing. VCDS returned a P0638 code. I read some posts and saw this video which describes cleaning the throttle body (I know its not an actual throttle body) and EGR tube above it. I can certainly try cleaning it, but I'm wondering if it's an electrical problem with the unit itself? I ask this because:
1) the car seemed to drive fine with no reduced performance, aside from a slight shudder when I shut it off. I tried clearing the code, and then went out for a 20 minute drive. During this time the glow plug and CEL were off.
2) afterwards, I shut the car off, went to the store. When I came back, I turned on the ignition, and the glow plug light started flashing even before the car started. If I tried clearing it, it just came right back, even with the engine off. I drove home, again with no performance issues.
So, with that in mind, is it possible to determine if the fault lies with the TB unit itself, and if so, would this be covered under the emissions warranty? If it is I'll just let them deal with it. Also, after cleaning the "throttle body" is there an adaptation that needs to be done, like on a gas powered car?
I'm assuming it's ok to drive for the next few days, it doesn't seem to be acting up.
